can you give me an idea
08.05.2020 16:34 # 1
erkerd5429
slm friends
gave an error alarm from LPG on Saturday, I took the car to gasoline, after a short distance, the catalytic converter gave a fault, stopped and waited after running it again gave the same error, I was on the way to the industry, slowly, I stopped the car. As if the starter is going to work, as if gasoline does not ignite or there is no gasoline. When it was taken over, it was as if the dirt was clogged, he was holding the car and letting the electronics look for it.
08.05.2020 16:34 # 2
yavuz25
there could be many reasons "Ermm"
08.05.2020 16:34 # 3
erkerd5429
thanks
08.05.2020 16:34 # 4
yavuz25
[QUOTE = erkerd5429] thanks [/ QUOTE]
we thank you. I wish we could solve your problem.
08.05.2020 16:34 # 5
djchaos
Catalytic is filled Check your LPG gasoline and LPG may be burning at the same time.
08.05.2020 16:34 # 6
tilbe307
You can already find information on this topic in the forum, but I know that this is a part that goes from an engine called catalytic convector in our vehicles to exhaust.
08.05.2020 16:34 # 7
erkerd5429
There are many topics related to the catalytic converter in the forum, but you don't understand what you wrote. "tilbe307" is not my problem, we thought we had a problem with "djchaos". We called the master yesterday, we found a problem.
08.05.2020 16:34 # 8
erkerd5429
The coil from the bottom of the socket where the suction manifold pressure sensor is attached, the cable has chassis, the tube brain, which has broken the tube brain, they were doing the cargo, I talked about it. but it is repeated, it has no time, he said if you put that piece on, the problem will disappear, there are friends who have problems.
08.05.2020 16:34 # 9
yavuz25
Thanks for your feedback. Get well soon. "Smile"
