can you give information about these pictures?
08.05.2020 17:07 # 1
gngburak
Greetings to everyone 206 What do you mean by the information on the display of my vehicle and on the screen for 3 lines? Can you help me?
08.05.2020 17:07 # 2
KenBlockJR
1) mileage to the next maintenance
2) oil level (now 5/6)
3) mileage with remaining fuel
4) mileage since the trip computer was reset < / div>
5) 100 kilometers of fuel consumption (in liters)
6) instantaneous fuel consumption
7) average speed since the trip computer was reset
Reviews
Reviews
Reviews
08.05.2020 17:07 # 3
Alicilik
1- Miles left for maintenance
2- Oil level of the vehicle
3-way computer data - the road that can be traveled with the current fuel
4-way computer data - The road since the reset
5-way computer data - Average fuel consumption since reset
6-trip computer data - Instantaneous fuel consumption
7-trip computer data - alerts when average speed since reset
8- exceeds your set speed
9-10 I don't know
Alicilik 2012-11-04 14:33:32
08.05.2020 17:07 # 4
EErgul
photo 1: shows the km remaining to the next vehicle maintenance. Your vehicle will be due for maintenance after 2900 km. Of course, I do not think that it will be very harmful if you do not expect this and have it done early. you can reset it if you have been cared for and still provides information about km or if you no longer want to see it. With the ignition off, hold down the button on the dial and turn on the ignition. The screen will start counting down from 10 and reset the maintenance counter for 10 seconds. Photo 2: shows the engine oil level from minimum to maximum (left to right). The box full of squares represents the empty box, the bottom lines represent the empty box. According to the photo, your engine's oil level is close to 85%. Do not panic when you see this screen zero, open the hood and manually check the level, because it has been wrong in my car too many times. You can reset the statistics in the memory of the information display by pressing and holding the button on which you change the interface of the information display. this reset resets your average fuel value, average speed and km in this photo. photo 5: shows your average fuel value in the last 100 km in liters / 100 km. (I'm not sure the value is the average in the last 100 km. but my personal opinion as a result of my reviews) photo 6: shows your instant fuel consumption value in liters / 100 km. If you go at a constant speed of 100 km, you can estimate the amount of gasoline the vehicle will burn at the end of 100 km in liters. You can change this to km / liter from the settings. estimates the vehicle's road in 1 liter of fuel in km. photo 7: tells you your average speed after the last reset. photo 8 I have no exact idea about photo 9 and photo 10. I have never seen these functions in my car. I couldn't have gone unnoticed. Knowing friends can help, but it is necessary to guess an application that gives an audible and written warning when you set the speed speed function or exceed the speed (120 km / h) set in the factory format. When you set "on", the system becomes active. When you set "off", this warning system is disabled. programming: programming in turkish. Therefore, in my estimation, various personal settings (such as delete selection time date setting, used speed unit km / h mil / h, fuel consumption unit L / 100km km / L) are arranged. I have no idea about Check Control.
08.05.2020 17:07 # 5
gngburak
Thank you very much for your time and reply. Thank you very much .... gngburak 2012-11-04 14:58:10
08.05.2020 17:07 # 6
Ozgur
I saw menus 8,9,10 for the first time, although I am not very interested in this subject. how did it come out?
08.05.2020 17:07 # 7
gngburak
It came out as soon as I clicked, but I press the keys, no action happens.
08.05.2020 17:07 # 8
Alicilik
Each time you press the button, ZAten moves to the next option. If you are between 3 and 7, you can reset the information if you hold them down while these are on the trip computer data. You can make changes by holding down on 8-9-10.
08.05.2020 17:07 # 9
gngburak
Okay, when I hold it between 3 and 7, it is reset but nothing happens in 8-9-10.
08.05.2020 17:07 # 10
Alicilik
[QUOTE = gngburak] ok when I hold it between 3 and 7, it will reset but nothing happens in 8-9-10. [/ QUOTE]
These options are active on the screen and may not be active in the vehicle's brain.
08.05.2020 17:07 # 11
gngburak
I understood how to make a transaction
08.05.2020 17:07 # 12
gngburak
figured out how to take action
08.05.2020 17:07 # 13
individual
For speed limiting. gives warning when you exceed the speed you set previously. (To make on-off)
9- You enter the speed limit here.
& nbsp;
& nbsp;
8 and 9 are also on my vehicle. (307)
individual 2012-11-04 17:14:37
08.05.2020 17:07 # 14
faldov
Friends, some pictures are gone, do you have a chance to add pictures to those who know about the subject?
08.05.2020 17:07 # 15
Alicilik
History
The amount of roads that can be driven with the current fuel
KM traveled since trip computer reset
Average fuel consumption since the trip computer reset (lt / 100km)
Instant fuel consumption (activated after 30km speed - lt / 100km)
< br>
Average speed since trip computer reset (kmh)
08.05.2020 17:07 # 16
faldov
Thank you, Thank you, & nbsp; "Thumbs
