Can someone who knows help small problems
08.05.2020 19:36 # 1
alfonsoxxx
Hello Friends Peugotturkey, after browsing and reviewing the forum, I bought the 307 xt 1.4 model the other day.
1. The rear trunk release handle is unobtrusive, but the top is broken, I need to change the rupture.
2.Tayip said the original tape, the former owner frame falls into the broken brake pressure.
How do I operate the tape controller under the 3rd rectifier.
alfonsoxxx 2016-01-11 16:50:29
08.05.2020 19:36 # 2
plawert
Good luck
1 - Trunk release lever needs to be changed.
2 - The tape on the vehicle is not original
3 - To use the tape control under the steering wheel, you will either attach the original tape or you will buy a compatible tape and use the control with an extra apparatus.
08.05.2020 19:36 # 3
alfonsoxxx
I was thinking like that, thank you
08.05.2020 19:36 # 4
erkan307
Thank you if he originally said the original tape, but even if this tape originally called the peugeot, it would be a pity that humanity is dead for a product worth 100 TL.
08.05.2020 19:36 # 5
alfonsoxxx
[QUOTE] I asked him if you wanted to make a difference, I would give the original tape.
