Can LPG on the Vehicle be Removed?
08.05.2020 15:09 # 1
Friends like a vehicle, but with LPG. I don't want LPG. Is it possible to disassemble? Or, if it is removed, will the car become fabricated again? Does its removal have an effect?
08.05.2020 15:09 # 2
If the holes drilled on the menifold are sealed nicely and the injector cables are soldered nicely again, I don't think it will be the problem. But why do you put it on? Let it go ... :)))
by the way what is the car ???
Is it certain that you will get used to it after 3 days. then I say I didn't put the light. As you know, gasoline is very expensive: (((((
08.05.2020 15:09 # 3
se®k@n
Dismantled; but you need to re-examine and change the license.
08.05.2020 15:09 # 4
Emre Ekrem
Isn't it necessary to replace the soldering of the injector cables? I'm asking because I don't know.
08.05.2020 15:09 # 5
Vehicle 206 Quiksilver 1.6 16V 110HP
