Can I Install a Cruise Control to the 307?
08.05.2020 16:01 # 1
kuantum
I want to have my vehicle fitted with a cruise control, but some people say that the cruise control is not something that can be retrofitted, while others may. It also has a question mark in my mind if the 307's electronics are very sensitive. In a nutshell:
1- Are speed stabilizers attached to 307s?
2- Is there any possibility to break the electronics, etc. assembly?
3- How much is the fee and where can I get it?
08.05.2020 16:01 # 2
only_younus
http://forum.peugeotturkey.com/forum_posts.asp?tıd=7478&title=307-cruise-control
http://forum.peugeotturkey.com/forum_posts.asp?tıd=8594&kw=h%fdz+sabitleme&title=hz-sabitleme-sistemi-ve-307
I think there is more information than you want if you can read it to the end
08.05.2020 16:01 # 3
metin
[QUOTE = quantum] I want to have a cruise control installed on my car, but some people say that the cruise control is not something that can be retrofitted, others may have it. Also, there is a question mark in my mind if the 307's electronics are very sensitive. In a nutshell:
There is as much information in the forum as you want. Please search before continuing the topic or continue with the same topic, otherwise the same topics cause pollution in the forum.
1- It is attached not only to the 307 but also to all models with electronic system instead of gas wire. 206-307-406 vs
2- There is a possibility of breaking the electronics. The reason is that normally wearing friends wear arms, connect the car to the computer and make it active, it works smoothly. But the service says that it should not only be done with this, but that the necessary modifications should be made to the cruise control. otherwise the brain might have malfunction. Of course, I have never seen a malfunction until now.
3- Our sponsor is 120 TL for Şahin Peugeot. depending on the bargaining you will make with the master, it varies between 20-50 TL. (By the way, authorized service does not wear)
08.05.2020 16:01 # 4
If you follow the forum on this topic, I will post an article into 1 error and I will explain what has been done from beginning to end with pictures.
08.05.2020 16:01 # 5
metin
Did you have Mustafa brother?
I said you did not put the photos you would send me to the second plan Sinirli
08.05.2020 16:01 # 6
[QUOTE = text]
I will do the assembly, but I did not have time: ((I have been outside for 2 days, but I could not send the pictures, but don't mind. If you come to iftar, will I make a CD?
the mustafakirl 2011-08-19 11:08:31
08.05.2020 16:01 # 7
metin
5% chance of coming to iftar Sırıtma you can directly mail
anyway let's not mess up the subject
08.05.2020 16:01 # 8
[QUOTE = mustafakirl of] [QUOTE = text]
Have you used PP2000 before?
08.05.2020 16:01 # 9
I used it once. I will always do it with friends in the private service I go to.
08.05.2020 16:01 # 10
I used [QUOTE = mustafakirli] once. I will always do it with friends in the private service I go to. [/ QUOTE]
So it's okay.
We are expecting your good news.
08.05.2020 16:01 # 11
metin
I used [QUOTE = koliva] [QUOTE = mustafakirli] once. I will always do it with friends in the private service I go to. [/ QUOTE]
So it's okay.
We are waiting for your good news, Mr. Koliva, Gülme
08.05.2020 16:01 # 12
I used [QUOTE = text] [QUOTE = koliva] [QUOTE = mustafakirli] once. I will always do it with friends in the private service I go to. [/ QUOTE]
So it's okay.
Mine is a strange story Kahkaha This weekend I will try to uninstall and reinstall it.
08.05.2020 16:01 # 13
kuantum
Could you please give a link under this title when you publish the article.
08.05.2020 16:01 # 14
I was going to say it :) we will be looking forward to it
08.05.2020 16:01 # 15
[QUOTE = quantum] [QUOTE = mustafakirli]
Of course I share the link here, my friend. I hope I can handle it without problems
