can i get some help 307
08.05.2020 16:32 # 1
mbuyukavci
hi
I just joined your peugeot family. I bought a 2004 model 307 xr hdi about a month. On the day I bought the vehicle, I filled the tank and after about 5 km, I encountered the error `` water in diesel filter ''. In this way, I continued on my way, after 350 km, I came to where I should come. Here I have a computer connected to the master said, `` They mixed the diesel water, let's change the filter '' OK I said we changed it, then I added a fuel additive würth. He said 100 km, come and clear the error. 100 km later I went back to the computer and encountered the fuel pump first circuit and fuel grade second circuit error. Then he sent me to an electrician, he said, "There is nothing in the man," said bin abi.
08.05.2020 16:32 # 2
mbuyukavci
hello
thank you I bought my car in 160000 to 15500. How expensive is the price accident there is only one right front fender changed.
08.05.2020 16:32 # 3
mbuyukavci
I always say, "How do we say we brought this bargain" & nbsp; it brings so cheap. the seller appeared before me. I am the first peugeot but I like it, it is written and drawn on the sites, it is problematic, it is problematic if you do not look at the car, it will cause a problem :) I took it in the engine up to 250000, the solid engine said, the masters are comfortable, but this error is getting worse if I solve it :)
08.05.2020 16:32 # 4
mbuyukavci
I'm in a super place then :) I'm just bored right now when this is resolved I can be relieved.
08.05.2020 16:32 # 5
06OzGuR06
I think that if you do not wear it, it is connected to the computer, the filter has changed, then there will be no problem.
Is the filter originally installed ??
08.05.2020 16:32 # 6
mbuyukavci
bosch brand was stuck but i am a little bit pimpirical in these matters.
08.05.2020 16:32 # 7
06OzGuR06
Change your refueling station after you run out of fuel. Absolutely, but this is very important. Take the fuel from
Total. Try Excellium Eurodizel as well. "Smile"
08.05.2020 16:32 # 8
mbuyukavci
they always told me to buy opet, I bought it from there and let's see the total experience :)
thank you
08.05.2020 16:32 # 9
06OzGuR06
You're welcome. "Smile" prefer stations close to the city center because others are more likely to be fraudulent.
Me I recommend it to you from Total, I had no problems so far.
Edit: Total Excellium is a euro diesel additive fuel and you don't need to add any additives.
06ÖZGüR06 2012-01-19 00:23:57
08.05.2020 16:32 # 10
mbuyukavci
I live in Burdur by name. Now when I look at it, there is no total in Burdur :(
Maybe you may be surprised but I am not surprised at this situation.
08.05.2020 16:32 # 11
06OzGuR06
[QUOTE = mbuyukavci] I live in Burdur by name. Now I look at Burdur, there is no total :(
Maybe you may be surprised, but I am not surprised at this situation. You can not find anything here. "smileys / smiley1.gif" border = "0" alt = "Smile" title = "Smile" />. It is located in Bucak district. The biggest district of Malum Burdur is Bucak. "Big & nbsp;
I think you are in the center of Burdur. I know the city center of Burdur is very small. If there is a shell, then try it
. "Smile"
08.05.2020 16:32 # 12
mbuyukavci
Shell is also close to Isparta. Now that he's closer, I'll give him a try
08.05.2020 16:32 # 13
06OzGuR06
There was BP in the center of Burdur close to the hospital & nbsp; how is it that the central station is better then maybe "Ermm"
08.05.2020 16:32 # 14
mbuyukavci
I bought it from the first bp, gave the error in Konya so I didn't go any more as I said I was getting opetten
08.05.2020 16:32 # 15
06OzGuR06
[QUOTE = mbuyukavci] I bought it from the first bp, gave the error in Konya, so I didn't go any more, as I said I was getting from the opet [/ QUOTE]
I understand then the shell is left, finally & nbsp; In other words, in the fuel business, more stations are more important than the brand.
Even if the brand is intact, there is a problem when the station is broken. "Unhappy"
08.05.2020 16:32 # 16
mbuyukavci
Hello
I came to konya today, I found a peugeot master in the industry. We changed the diesel filter in the vehicle and realized that there is neither water in the diesel nor the problem in the filter, there is only one in the back, there is a problem in it. He needs to change but the room may not be certain: ((
08.05.2020 16:32 # 17
cey cey
those who do not know the satin work, do not speak, change the problem until the problem is gone, change everything in the car.
08.05.2020 16:32 # 18
mbuyukavci
They led me to another master today, and the pressure regulator on the diesel pump broke down. It's not a ramp stop, that's the problem. I do not understand anything wanted hu: s
08.05.2020 16:32 # 19
mbuyukavci
Water in diesel filter error was causing the diesel filter cable of the diesel filter to be short-circuited. Corrected, now we have disconnected the cables have been solved :)) mbuyukavci 2012-02-16 23:31:23
08.05.2020 16:32 # 20
gorkemteke
good luck i'm glad that the problem is solved
