CAN I BOTTLE THE ANPHONE-FREE MID?
08.05.2020 19:18 # 1
umitgun
Hello friends,
I want to connect mid-bass to my vehicle, but can I connect it in a non-amplified way or is it necessary?
08.05.2020 19:18 # 2
samet206
I was also researching, connecting, even trying it, but it makes more sense to connect it from normal coax if it is not used in the system. Apart from that, it is more logical to connect the coax, as I said, there is no problem in it.
08.05.2020 19:18 # 3
umitgun
I do not expect performance anyway, it is enough for me to hit a sweet :)
08.05.2020 19:18 # 4
samet206
If you want master sweet bass without amphitheater, the oval will give a more satisfactory result, but in my opinion, if you bring a suitable MID suit for your tape's output power and install it appropriately, there will be no bad results. I will do it, but I do not want to put an oval in the panzidus, so I still have not decided so I bought a 4-way coax for the front doors.
08.05.2020 19:18 # 5
umitgun
So how do I connect the car to the middle of the car, there are no cable entries for the speaker in my back doors, I searched but I couldn't find it :)
08.05.2020 19:18 # 6
samet206
The wiring must be pulled on the back doors, even if there is no speaker. In some cases, it may not happen. The electrician pulls it in a proper way. It is a simple process. Of course, it is necessary to connect their crossovers or something properly. Also, after removing the door trim, I would definitely recommend you to make a sound insulation, if not at all, do not close it without putting a styrofoam .
