Can friends with knowledge look
10.06.2020 02:08 # 1
FatihBall
First of all, my friends, I have a problem, the answers you give are very valuable to me. My vehicle 1.6 hdi, when I parked the vehicle for 2 hours and got into the vehicle again, my vehicle did not work The tape, lock, windows, flasher work very well, but the click sound is heard when I start. The starter does not turn on and there is a click sound when starting, there is no dimming in the headlights when starting, only the interior ambience, ie the lights of the glass on-off buttons go off when I start, there is no problem in the indicators, before that, my vehicle would run on a single starter. Your comments on the subject are very valuable to me
10.06.2020 09:47 # 2
Starter coals or automatic starter may be broken. Do not try to hitting it, sir.
10.06.2020 10:19 # 3
FatihBall
Wouldn't the starter or the coal give a symptom because suddenly something like this happened motor is like a monster
10.06.2020 12:40 # 4
ismailkaya
Ayeykümselem, there are two possibilities, as the sonerkyl brain says, the starter dynomo is the second possibility, you hear the crank sensor click, or my problem is caused by the crank sensor, this possibility should be evaluated.
10.06.2020 13:05 # 5
FatihBall
When I turn on the ignition, only the sound of the role is heard
10.06.2020 17:00 # 6
FatihBall
The master looked at the vehicle, I think he pulled the plus cable from the starter motor, the vehicle is starting, but this time the vehicle does not work, what can I do now it goes to the master with the tractor
11.06.2020 08:34 # 7
one value possibility might be immo. Have the best detection look for a fault record with the original device.
