Camshaft difference malfunction
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 3008 (2009-2015)
08.05.2020 19:36 # 1
tilbe307
My friends vehicle is 3008 Vti 1.6 engine. There is a new problem I have noticed, especially in the 2nd gear, as it rose from 2000 rpm to 3000 rpm, trembling (shaking back and forth) occurred. We connected to the computer. Exhaust shaft defect appeared. however, the malfunction lamp does not illuminate. Could my problem be a sentence shift?
08.05.2020 19:36 # 2
zerzevat
hi .... I was reading this engine while reading in a foreign forum. There is a chronic problem with the motor. a setting - a correction is required. investigate it.
08.05.2020 19:36 # 3
zerzevat
If you have solved the problem, please inform that the readers will benefit.
08.05.2020 19:36 # 4
zerzevat
Dear teacher, has the problem been solved?
08.05.2020 19:36 # 5
tilbe307
Sorry I shouldn't go into the forum, my master changed the timing tensioner. solved, but sometimes the same misfire situation does not happen, it seems that we will have to connect to the computer and work on it again when I have the opportunity.
08.05.2020 19:36 # 6
zerzevat
It was not something to happen with the tensioner. it has to be a piece change-a serious craftsmanship.
I will say consult the service, but .. services may not be very competent. they call the center and have a problem. Let them meet an engineer at the center.
I think that free fixes are required because there is a fabricated error.
