camber outward
08.05.2020 16:08 # 1
ugur_xs
friends, I have a question in 206 how do we make the rear wheels stick out, do we have a chance to play camber
08.05.2020 16:08 # 2
sedatdatse
you will get a flange or you will get as many mm as you want. But the mudguard is mindful.
08.05.2020 16:08 # 3
ugur_xs
It is not a flange, it is not a job.
08.05.2020 16:08 # 4
ugur_xs
when you say "out"
08.05.2020 16:08 # 5
I Love My Pug
In its simplest form, the camber adjustment is to change the angle at which the tire touches the ground. The tire that is pressed at right angles to the ground provides maximum contact on the flat road.This provides the best acceleration and braking distance. However, the negative camber adjustment will change the driving dynamics. Tires with inner parts contacting the road provide less grip on the straight road, while the center of gravity changes and the vehicle flexes, giving more grip. You can see negative (-) and positive (+) camber angles in the pictures. It is generally not possible to play with camber angles in standard vehicles. It is possible to make this adjustment with camber correction arm. As you can see in the picture, there are screw adjustment positions. excerpt .. 106 -206 -306they have a rear CAMBER adjustment ... nothing is fixed ... it is always FULLY flat .. to have a camber adjustment, there must be a completely independent suspension, but on the rear side torsion 106 206 306 and similar vehicles camber is another it can be adjusted even in the system. Between the place where the hub is attached to the Torsion bar, you can set as many camber as you want by placing a thick washer used by rotbalanists. But this is hearsay.
08.05.2020 16:08 # 6
Nice information. Thanks.
08.05.2020 16:08 # 7
I Love My Pug
[QUOTE = koliva] Nice information. Thanks. [/ QUOTE]
you are welcome :)
08.05.2020 16:08 # 8
metin
I learned something new
08.05.2020 16:08 # 9
taksicicocuk
Explanation has been wonderful, my land has seen that light in you: D
good health in your hand
08.05.2020 16:08 # 10
I can not stop taking care of the person alone, but in the Peugeot Citroen, the rear tires are lightly slanted, and they have been made consciously for better grip in the bends. Maybe it may not be like that in every model, but in 206s, 306s vs so "Blink"
& nbsp;
Look at the rear of the vehicle. But in some vehicles, as torsion balls are broken, there is a greater rate of sliding than usual. Of course there is an abnormal situation due to this malfunction
CeCoLi 2011-09-21 10:05:53
08.05.2020 16:08 # 11
08.05.2020 16:08 # 12
berk2309
As far as I know, when the car reaches 90 km in 307s, the tires are spread outwards, and the negative camber like & nbsp;
08.05.2020 16:08 # 13
[QUOTE = berk2309] as far as I know, when the car reaches 90 km speed in 307s, the tires are spread outwards, and negative camber like & nbsp; [/ QUOTE]
& nbsp;
There is no such feature. There is no such thing as tires in any vehicle suffer according to surate. A completely wrong information.
& nbsp;
For example, they lie on the road when Mercedes faces, & nbsp; sticks on the road etc etc completely wrong ...
08.05.2020 16:08 # 14
berk2309
many times the tires are separated on the way: D
08.05.2020 16:08 # 15
[QUOTE = berk2309] many times the tires are separated on the road: D [/ QUOTE]
& nbsp;
They're not leaving. Where do you get out ??? "Grin" & nbsp;
& nbsp;
But our vehicles are lying down lightly on the vehicles, they are already flat. /smiley2.gif "height =" 20 "width =" 20 "border =" 0 "alt =" Blink "title =" Blink "/>
Same shape where it stops
08.05.2020 16:08 # 16
berk2309
no, but the day passed by my friend fade & nbsp; He said he was behind me until he came down from the ship and came down to the magosa, while your tires were spreading, he said to me & nbsp; he even wrote one more thing in the forum and if i find it i'll show & nbsp;
08.05.2020 16:08 # 17
berk2309
http://forum.peugeotturkey.com/forum_posts.asp?TID=7543&title=307-about-bir-iki-soru-ya-da-sorun & nbsp; here is a guest at a friend & nbsp;
08.05.2020 16:08 # 18
[QUOTE = berk2309] no, but my friend's day faded & nbsp; He said he was behind me until he came down from the ship and came down to the magosa, while your tires were spreading, he said to me & nbsp; he even wrote one more thing in the forum and if i find it i'll show & nbsp; [/ QUOTE]
& nbsp;
I think there is an eye misconception ... & nbsp; For example, as the old BMW Mercedes load up, it hurts to the sides. This is in the structure of the suspension. But there is no such situation in our vehicles. You'll know if you examine the backstrap. The tire's pain does not change with or without load
08.05.2020 16:08 # 19
berk2309
It is true but I heard it from many people :)
08.05.2020 16:08 # 20
[QUOTE = berk2309] is true, of course, but I heard it from many people :) [/ QUOTE]
& nbsp;
Okay, what do I mean? It is already lightly lean on our vehicles. But they look on the road because they don't look carefully while standing, but "Blink" & nbsp;
Page : / 2
