Calibration
08.05.2020 15:46 # 1
SERVET
How to do the calibration process completely. Can we do it ourselves, I would be very happy if they tell my request from the masters.
08.05.2020 15:46 # 2
When I say calibration ?? Sorry, it was a very busy day.
08.05.2020 15:46 # 3
berk2309
Are you in throttle or calibration say
08.05.2020 15:46 # 4
SERVET
yes throttle calibration.
08.05.2020 15:46 # 5
tilbe307
I know that this calibration is done by computer. When I did it, I did it with a computer.
08.05.2020 15:46 # 6
metin
What do you calibrate according to what some situations do not require calibration. What is your operation that you are trying to calibrate?
08.05.2020 15:46 # 7
SERVET
I have a 2000 engine 406 sv vehicle. My first problem with LPG is that my vehicle is running at 20-30 seconds when the engine is cold, it will seem to stop when it gives gas after kicking for about 20-30 seconds.
The second problem is that the stoppage is piling up during take-off and the gas is 0.5 seconds delayed.
08.05.2020 15:46 # 8
metin
I think there may be another problem not with calibration. Because when there is gas calibration, pressing the throttle, opening the butterfly etc. they are calibrated. I think it will cause trouble if calibration is continuous.
08.05.2020 15:46 # 9
SERVET
My teacher said I had the computer connected and looked at the private service, but the engine was hot, there was no problem, all the sensors were intact, I did some research on this forum, if it was something I could do, I said to do a gas butterfly calibration, but I don't know how. so I opened the subject so that someone who knows would explain it.
08.05.2020 15:46 # 10
metin
Can you write the model of the vehicle model model year in the signature section, we don't have to ask every time,
Mr. Koliva is an excerpt from my brother;
Calibration means synchronizing the current position of the butterfly with the brain. If you play on the spot while you are cleaning, you may need to calibrate. Calibration is done simply. The vehicle is stopped. Then the starter is pressed and run for 10 seconds. Then it is stopped for 10 seconds. This process may need to be repeated several times. Good luck with
