Cable under the seat
08.05.2020 17:55 # 1
halilefe
Friends, a while ago, my car had taken water under the driver's seat, and I had to change the underfloors. After a while, the air bag started to burn. Reviews
Reviews
http://o1309.hizliresim.com/1f/1/s53jc.jpg
08.05.2020 17:55 # 2
Bunyamin.Kar
I'll say the airbag socket under the seat, but the airbag cables are usually orange
08.05.2020 17:55 # 3
halilefe
Everybody, look under the seat, the socket is out, I said, I disassembled it.
08.05.2020 17:55 # 4
halilefe
08.05.2020 17:55 # 5
error
Is there an air bag on the side of the teacher seat?
if yes there must be a socket on that airbag seat
08.05.2020 17:55 # 6
halilefe
Here I couldn't find it
08.05.2020 17:55 # 7
error
If there is no airbag in the seat, the vehicle that will remain idle on that cable may be wired as if it were an airbag
08.05.2020 17:55 # 8
halilefe
I have an airbag in my car, but I don't know if there is an airbag in the seat, my airbag lamp started to light up constantly. I wanted to ask when I saw that cable in the open, I removed the seat, there is no socket under the cable to enter.
08.05.2020 17:55 # 9
error
then there is no airbag in your seat, but if it got water then that socket might have turned on the airbag lamp, an interesting problem
08.05.2020 17:55 # 10
Alicilik
By removing the battery terminal of the vehicle,
Remove the existing sockets and make sure that there is some contact with the wd40 of the rim and the rust and friction.
Reseat the socket and put on the pole head. After 1 minute turn on the vehicle's parking lamp and wake the vehicle
If there is a photo, we can help more clearly that part. receptivity 2013-09-01 16:32:26
08.05.2020 17:55 # 11
halilefe
Üsdar I could not find a place to plug this socket was standing idle under the front seat
http://o1309.hizliresim.com/1f/1/s53jc.jpg picture here
08.05.2020 17:55 # 12
Alicilik
it is hard to understand from this photo. The cable coming out of the .clips may be bending somewhere else.
08.05.2020 17:55 # 13
halilefe
I understood then, if I connect it to the computer first, maybe the exact location of the problem will arise.
08.05.2020 17:55 # 14
g-demir
If the seat has an airbag, it appears on the side. And it definitely belongs to a socket, it can't be that idle
08.05.2020 17:55 # 15
hsnsnl
If I think it is the driver's license belt, do you pay any attention to the light?
08.05.2020 17:55 # 16
halilefe
There is no seat belt there is a socket on the end.
