Cable I forgot to plug in (with picture)
08.05.2020 17:15 # 1
_semihk_
Let me ask the first question of 2013 for myself ...
on the vehicle's engine I had dismantled the cables ... I just forgot to plug the cable I marked in the picture .. I came to mind when the engine malfunction light was on the road, I put on the hemendrup and the light disappeared after a while .. it did not come out again .. could have caused permanent damage: S there has been a low traction since then I think: (
08.05.2020 17:15 # 2
xMEGANx
Why did you remove the wires, Mr. Semih?
08.05.2020 17:15 # 3
_semihk_
the heater is inside the kidnapper inside .. while doing it, i clean it in hm, i had to disassemble and distribute it .. then i forgot it :)
08.05.2020 17:15 # 4
xMEGANx
[QUOTE = _semihk_] the radiator was missing the inside of it. :) Well, there is nothing to do now, of course.
08.05.2020 17:15 # 5
_semihk_
of course, how did he deal with my brother?
08.05.2020 17:15 # 6
serkan719
no need to wipe & nbsp;
because it is ok if it does not show on the indicator.
I removed the turbo hose and started the car & nbsp;
my engine fault light came on & nbsp;
put on the hose and went out after 1 km
08.05.2020 17:15 # 7
xMEGANx
[QUOTE = _semihk_], of course, how did he deal with it, brother? The fault light remains registered on the computer, I don't think it will be damaged, but if the fault remains registered, you can delete it. I think when you go to delete or tell the service sometime.
08.05.2020 17:15 # 8
istanbullu_3886
the socket of the socket air flow meter means no problem after the fault light goes out.
08.05.2020 17:15 # 9
_semihk_
the traction nie fell that: S means sometimes I shouldn't be able to tamper with the dead
08.05.2020 17:15 # 10
tellotello
Traction may have fallen as the flow meter malfunction appears in the memory, sir. Connect it to the computer and try to clear the error. The system may be thinking that the flow meter is measuring incorrectly due to an error.
08.05.2020 17:15 # 11
_semihk_
this is exactly what I think of in my mind: S & nbsp;
ecu seems to be problematic now, after all, flowmetry
