Cable from Luggage to Doors? |
| • Homepage » PEUGEOT MODIFIED PLATFORM » Peugeot Sound Systems | |
| 08.05.2020 18:40 | # 1 |
| 08.05.2020 18:40 | # 2 |
Alicilik |
I did the process you mentioned on my own vehicle. What kind of demonism do you want? If you remove the bottom of the door rubber, the carpet is wasted and when you lift the carpet slightly, you will see the cable harness and pass it there. There is a bridge on the middle pole to pass it to the door. To reach that bridge, you have to remove the side style. You will remove the side column from above from below. Firstly pull out the seat belt adjuster and unfasten it with 20 torx. Then pull it out of the clips and release it from top to bottom. If it is not enough, unscrew the bottom seat fastener nut below and remove the black part. |
| 08.05.2020 18:40 | # 3 |
It was very troublesome. Apparently, installing a new tape recorder and attaching a coax speaker using ready-made cables. Thanks for your reply.
