C4 Oil Change
08.05.2020 15:24 # 1
Asi Kaptan
My brothers went to change the oil of the vehicle at the weekend, we turned the ignition after changing the signal about how many kilometers before the fool will be changed.
If I haven't sensed the oil yet, is there a malfunction?
08.05.2020 15:24 # 2
metin
Don't expect oil to perceive it because it doesn't.
the person who changes the oil resets the oil meter.
08.05.2020 15:24 # 3
[QUOTE = Rebel Captain]
They forgot to reset, or there is no mechanism called detection. So you can:
1. Turn the vehicle's control to the S position.
2. Press the button immediately after the indicator flashing and keep it pressed.
3. Operate the vehicle while holding it down.
4. Then wait until 0 appears on the screen.
5. Reset process is finished.
08.05.2020 15:24 # 4
Asi Kaptan
Just like the 307, the steering wheel is not there, there is a button on the dashboard and in front of the digital CHECK button.
08.05.2020 15:24 # 5
[QUOTE = Rebel Captain] Just like 307, the steering wheel is not there, there is a button on the dashboard and in front of the digital with CHECK button. [/ QUOTE]
This process was for C4. The button I said goes through as the Trip button and is located right behind the speedometer. Good luck with.
08.05.2020 15:24 # 6
Asi Kaptan
Brother trip shows how many kms ..
08.05.2020 15:24 # 7
[QUOTE = Rebel Captain] Brother trip shows how many kms have gone .. [/ QUOTE]
I'm talking about the button. Is there no button for the odometer or the service counter that flashes? Try what I say and write the results here.
08.05.2020 15:24 # 8
Asi Kaptan
[QUOTE = koliva] [QUOTE = Rebel Captain] Brother shows how many kilometers the trip has gone .. [/ QUOTE]
[/ QUOTE] I kept the trip button pressed, I started the car fault point = 10 9 8 7 6 5 4 3 2 1 0 did so then wrote how many km it will change ..
Thank you Avbi ..
08.05.2020 15:24 # 9
[QUOTE = Rebel Captain] [QUOTE = koliva] [QUOTE = Rebel Captain] Brother shows how many kilometers the trip has gone .. [/ QUOTE]
Thank You Avbi .. [/ QUOTE]
Tamamdir. Get well soon Göz Kırpma
Koliva 2011-05-09 20:58:15
