c4 Gas cut at 3000 rpm?
08.05.2020 18:05 # 1
kuscu38
Friends is the place where I say the gearbox of the lion piece was up. So my friend's car was confiscated :) there is a problem like that
The vehicle should be 2005-2006 c4 at 3000 rpm even if the vehicle is not in gear, it does not deliver gas after 3000 rpm. 24km in 1st gear. - 48th in 2nd gear - 67 km in 3rd gear, do not you think why?
08.05.2020 18:05 # 2
hsnsnl
If I think a diesel vehicle
08.05.2020 18:05 # 3
kuscu38
[QUOTE = hsnsnl] if I think a diesel vehicle [/ QUOTE]
eft car diesel i have used c4 before but never had gas cut like this :)
08.05.2020 18:05 # 4
hsnsnl
I have to open the turbo in those times, in the turbocharged vehicle ... I couldn't remember the turbo valve, I couldn't remember the temperature .. You can have this problem at the back of the engine (if you are working with the air, even if you are pressurized, you can have this problem, if the pressure comes out, you can stay at certain miles) When you smell it, the turbo will open and this valve (throwing the smoke inside the engine without compressing it) makes it black out. Exhaust .. the valve does not breathe.
08.05.2020 18:05 # 5
hsnsnl
[QUOTE] you stay) duruo, when you smell the gas, the turbo will open and this valve (it blows the smoke inside the engine without squeezing it together) makes it exhaust .. the valve does not have a big possibility .. [/ QUOTE]
my teacher, turbo electroplating night.
08.05.2020 18:05 # 6
erman0464
[QUOTE = kuscu38] Friends is the place where I say the gearbox of the lion piece was up. So my friend's car was confiscated :) there is a problem like that
The same thing that could have happened to me in my flow meter. Try to clean the flow meter
08.05.2020 18:05 # 7
esra_16
Hello, my car did not exceed 3000 cycles. My mechanic took everything he could do without changing the part and he said that he would change the air flow meter, and he fixed it as he said.
08.05.2020 18:05 # 8
kuscu38
[QUOTE = esra_16] Hello, my car did not exceed 3000 cycles. My mechanic took it, he tried everything he could do without changing the part, and finally he said, let's change the air flow meter, it would definitely fix it, and it was like he put in the new part and the problem was improved. Meanwhile, the vehicle did not light in the fault light. . [/ QUOTE]
friends, thank you all separately. the thing that is called air flow meter can be egr, the vehicle is left in between me, a sleepy distress gazlıyamam my friend :)
08.05.2020 18:05 # 9
cerci07
Remove the plug of the flow meter and try it. If the problem is not in the flow meter, connect to pp2000 and make a call.
08.05.2020 18:05 # 10
kuscu38
this is the instrument called flow meter. it feels like air cleaned and then cleaned with balatas prey! What was the new one you bought?
