by yourself
08.05.2020 15:35 # 1
ask307
hi peugeot family, when my friends went on the road last week, the headlights of my car lit up, the self-wipers worked, at the same time, a warning sound came like frost, I called the service, the battery is running out, it is 1.5 years since the battery is dead, the battery will run out in a short time, or it may be related to the brain
08.05.2020 15:35 # 2
ask307
I did not do such a thing when the first battery was exhausted, but I heard the sound event a couple of times.
08.05.2020 15:35 # 3
ask307
God bless if it wasn't a brain or something
08.05.2020 15:35 # 4
MagicPerformance
If the vehicle is installed, it ends in 1 month :)
08.05.2020 15:35 # 5
metin
it may be from the brain because everything passes through the brain, for example, even the command of the tape goes to the brain from the brain to the tape. There are abnormalities when there is trouble in the brain.
I had read somewhere, when they pressed the horn, they said the sprinklers were splashing water.
Since the place of the brain is in a very critical place, you can get water and eat the head. You can find the necessary precautions to prevent your brain from getting water in the forum.
08.05.2020 15:35 # 6
ask307
[QUOTE = umutrizaergen] if the car is installed, it ends in 1 month :) [/ QUOTE]
There is bass amp. I listen to the tape after the vehicle stops, if it's over then normal time
08.05.2020 15:35 # 7
ask307
[QUOTE = text]
if it is related to the brain, does not it have to burn
08.05.2020 15:35 # 8
It was a similar incident from my head. The rain sensor was working on its own, pressing the horn from time to time, the warning sounds you said were coming or something. In my case, BSI was receiving water. There's a grille under the ten windows, outside, on the sofor side. He can get out of the grid and there is a evacuation point inside. If the Egero drain point is obstructed (leaf camus, etc.) there is water accumulating and some water leaks into the interior. Since BSI is just below the rate, the first to be affected is BSI. Check it out and clean that area.
08.05.2020 15:35 # 9
ask307
[QUOTE = koliva] I had a similar incident from my head. The rain sensor was working on its own, pressing the horn from time to time, the warning sounds you said were coming or something. In my case, BSI was receiving water. There's a grille under the ten windows, outside, on the sofor side. He can get out of the grid and there is a evacuation point inside. If the Egero drain point is obstructed (leaf camus, etc.) there is water accumulating and some water leaks into the interior. Since BSI is just below the rate, the first to be affected is BSI. Check it out and clean that area.
I understood the place you said bro, let me check it, it may be like you said
08.05.2020 15:35 # 10
Does the vehicle have a headlight and wiper sensor?
08.05.2020 15:35 # 11
inceyasar
I heard that the car's brain was mingled when the battery was running out or the charcoal of the charger was running out. I do not know if the battery, the charger is in our cars, but it would be a conjunction.
08.05.2020 15:35 # 12
Saleeh
After my brother installed a white light bulb in the car, we had similar problems. the right windshield descends but does not remain. the wipers are self-powered, etc. The problem is most likely caused by the brain. Also, let me point out that these problems are getting better with time. Weird & nbsp; "Grin"
08.05.2020 15:35 # 13
[QUOTE = text]
can be from the brain because everything passes through the brain in these vehicles. There are abnormalities when there is a problem in the brain.
& nbsp;
Since the location of the brain is in a very critical place, you can get water and eat your head as soon as possible. In the forum, you can find the necessary precautions to prevent the water from going to the brain.
In the forum, I could not find the issue of protecting the brain. How can I protect it from passing below and the brain is getting wet.
08.05.2020 15:35 # 14
badcombatant
All I have to say is I hope the tool has no problem in BSI
08.05.2020 15:35 # 15
werty
It was such a problem that I had my renault brand vehicle. It happened after washing. The headlights were burned, the wipers were wiped, the machine had an automatic elfren, it was hurting. ” Of course, I can't exactly tell you what it is.
