BUZZING
08.05.2020 21:14 # 1
serkan066066
selamun aleykum. When my vehicle is on the road, a humming noise comes in or out of the front. I thought it might be one of the wheels. I renewed the wheels but not over. When looking on the internet, it is said that there may be flow balls. Does anyone have an estimate or knowledge?
08.05.2020 21:14 # 2
bilo131
The wheel is probably from the hub ball. Put the vehicle in neutral, lift the right side with a jack, turn the wheel with your hand Listen to the sound, the wheel turns hard, probably, try the same for the left side, and you will see the problem.
08.05.2020 21:14 # 3
just like hub bearings, there is a problem.
08.05.2020 21:14 # 4
serkan066066
thanks I will go and check it out at the weekend.
08.05.2020 21:14 # 5
ismailkaya
the same trouble was on my side, we did not change the wheels, then there are 3 places, one on the right, left wheel, and one of the axle middle suspension bearing is defective. I also had a sound, I first changed the wheel ball, the sound was still going on, then we found that there was an axle middle bearing, I did not have the opportunity to change it. tried;))))
08.05.2020 21:14 # 6
serkan066066
thank god my voice ceased after the wheel ball changed, but this time, the loud sound came from the left front
08.05.2020 21:14 # 7
[QUOTE = serkan066066] my voice was cut off after the wheel ball changed, but at this time, the loud sound started from the left front [/ QUOTE]
z rot probably serkan
08.05.2020 21:14 # 8
serkan066066
just like z rot and chock changed problem solved thanks
