Buy peugeout 407 1.6 HDi Comfort?
08.05.2020 17:57 # 1
silivriserdar
www.sahibinden.com/ilan/vasita-otomobil-peugeot-1.6-hdi-ilk-sahibinden-orj.110.000-kmde-svs-bakimli-kazasiz-138209786/detay/
Friends, how am I going to buy the vehicle in this announcement tomorrow? If anyone knows who has a chronic problem, who is using it, I would be glad if he helps.
silivriserd is 2013-09-23 15:32:48
08.05.2020 17:57 # 2
qqyyxx
My teacher is like a monster, the car is clean, as long as it is used with humane emotions, there is no more comfortable and handsome vehicle you can get to those figures. not to be economical. When it comes to chronic problem, chronic problem means problems that may or may have occurred across the same type of vehicles, which is actually a good thing, at least the solution is clear. There are also problems that spend a lot of money through trial and error, the cause of which cannot be found, God bless. it is not possible for the vehicles you buy otherwise to not malfunction. It is enough to be well-kept and to eliminate a small malfunction in time before it grows. I think that everybody who appreciates his property will do this.
08.05.2020 17:57 # 3
silivriserdar
Thank you very much, everybody says good, I hope I don't have a problem while selling this vehicle.
08.05.2020 17:57 # 4
Burak
Scuffs on the bumpers in the bodywork caught my eye, and it seems like a vehicle that can be bought if there is no good engine play.
08.05.2020 17:57 # 5
silivriserdar
[QUOTE = Burak044] Scuffs on the bumpers in the bodywork caught my eye, it seems like a vehicle to be bought if there is no good engine play right away.
When it comes to playing in the engine, it was said that only maintenance was done. Other than that, he had no problem.
08.05.2020 17:57 # 6
elsoberano
get expertise in a good service sometimes there is no clear information on trmer, they may have crashed the car and made it out of the pocket. 407s have chronic malfunction tire pressure sensor malfunction. One of the most economical and comfortable vehicles
08.05.2020 17:57 # 7
tongucuk
slm as far as i can see this vehicle is painted front rear bumpers is not a normal zero vehicle, after all, there are small knocks in the vehicle but i think the most important problem is not all one but they can present the car dealers with the attention of the rami market dealers as well as a few people and they can even present the vehicles that go out the curtain I took a lot of artistic pictures, as friends say, it may not come out of the tramer, from the insurance company, even from the authorized peugeot service, with a chassis and engine number.
08.05.2020 17:57 # 8
He says there is a speed control, but no speed control?
08.05.2020 17:57 # 9
qqyyxx
yes, the gallery event is really a very important issue. The guys can say that we are the second owner. There are also dealers who clean their work, but unfortunately most of the dealers in Istanbul are unfortunately fraudulent.
08.05.2020 17:57 # 10
Mustafa-almanya
My car is 407 sw diesel automatic. My car is the 11th month of 2005. The power steering is electrically powered and has a chronic tremor problem. An expensive piece. I think check it out. I think the display for the air conditioner and tape of the vehicle is broken. Even if it's not broken, give it a try when the car is getting hot. You may need to change it if it becomes unreadable. Instead, you can wear the colored one, but the display will have to be introduced after tactic. I couldn't find a place to promote the display in Germany. Finally I took the necessary cable and made it myself. Replacing the glow plugs is very difficult (I say for 2.0 HDI). If the same is about 1.6 HDIs, the change can be expensive. Have a mechanic check if they are working.
These come to my mind ...
08.05.2020 17:57 # 11
Mustafa-almanya
I forgot to say, My tool sw. While cargo from Turkey was a little form, even though the car behind should hardly the adult bayagi was cumbersome. 1.6 HDI would please you in terms of performance. I think about it too ...
08.05.2020 17:57 # 12
Mustafa-almanya
I also have the same tape. Unfortunately, there is no MP3 playback feature.
08.05.2020 17:57 # 13
silivriserdar
[QUOTE = ramazanturan81] slm, as far as I can see, this vehicle's front rear bumpers are not painted, it is not normal zero vehicle. they were able to present the car, I suspect it was obviously I have taken many artistic pictures, as the friends say, it may not come out of the tramer, even from the authorized peugeot service with the chassis and engine no.
Exactly what you say is true, there are small bumps and it is cooling people and when we give up. Thanks to all the friends who commented, thanks to Allah, I made a reasonable decision thanks to you. Sometimes people forget what they know and panic. Give such a forum from Allah and experienced people are helping with their good intentions. Experience and experience is a very important thing.
08.05.2020 17:57 # 14
silivriserdar
[QUOTE = Mustafa-germany] My car is 407 sw diesel automatic. My car is the 11th month of 2005. The power steering is electrically powered and has a chronic tremor problem. An expensive piece. I think check it out. I think the display for the air conditioner and tape of the vehicle is broken. Even if it's not broken, give it a try when the car is getting hot. You may need to change it if it becomes unreadable. Instead, you can wear the colored one, but the display will have to be introduced after tactic. I couldn't find a place to promote the display in Germany. Finally I took the necessary cable and made it myself. Replacing the glow plugs is very difficult (I say for 2.0 HDI). If the same is about 1.6 HDIs, the change can be expensive. Have a mechanic check if they are working.
Thank you, thank you very much, the information you provided is very important in my mind, but the vehicle is 407, but I can turn to a different Peugeout model.
08.05.2020 17:57 # 15
Burak
frankly I am glad you don't buy I sit in Eyüp artillery rami market by walking to me 15 minutes above I know the rami market well, I do not trust, but I have not come across a good car until this time. 407 are beautiful tools that I have in mind, one day I think you will find the cleaner to have 407 and keep looking.
