butterfly glasses whirling
08.05.2020 17:26 # 1
elsoberano
friends my 307 single door back butterfly is making glass shitting how do i cut it. (the back corner of the glass is worth the sheet) elsoberano 2013-03-19 12:44:17
08.05.2020 17:26 # 2
impact
oo get past .. i guess i don't know how there is a problem with the hinges
08.05.2020 17:26 # 3
hsnsnl
there is no problem on the glass side, but it is necessary to overhaul them with 3 rivets attached to the sheet side.
08.05.2020 17:26 # 4
elsoberano
[QUOTE = impact] Oh, get past .. I guess I don't know how there is a problem with the hinges, but it may have made the hinge sagging from the screw loosening .. [/ QUOTE]
how is the solution? first I have to check the screws then i checked today & nbsp; comes from butterfly glass. I am obsessed with an awful sound of head. Can hinge change?
08.05.2020 17:26 # 5
elsoberano
[QUOTE = hsnsnl] there is no problem on the glass side, but it is necessary to overhaul them with 3 rivets attached to the sheet side [/ QUOTE]
I think how the rivet is handled looks like a master way.
08.05.2020 17:26 # 6
elsoberano
How to remove the door trim from the friends, where to start to remove the screw, etc.?
08.05.2020 17:26 # 7
hsnsnl
[QUOTE = elsoberano] [QUOTE = hsnsnl] There is no problem on the glass side, but it is necessary to overhaul them with 3 rivets attached to the sheet side. / QUOTE] exactly, my teacher needs a rivet machine and you need a rivet :)
After inserting the tors (screws) on the door inserts, you will pull the nails behind them.
08.05.2020 17:26 # 8
elsoberano
After inserting the tors (screws) on the door trim, you will pull the nails towards you, they have nails on the back, they are already broken, you can get the new ones from the pieces and keep them with you [/ QUOTE]
I saw one at the end of the door. I think I need to unscrew them before opening the door. "0" alt = "T o ngue" title = "T o ngue" />.o let me take a look at the rivet business. Have you started hearing once, the sound is ringing in my ear.
08.05.2020 17:26 # 9
Alicilik
Throw me a private VIN (chassis number)
08.05.2020 17:26 # 10
elsoberano
I sent my brother
08.05.2020 17:26 # 11
Alicilik
Brother sedre is there but I can't open it without Xp, you know. I was able to find them from the servicebox from that face.
08.05.2020 17:26 # 12
elsoberano
Thanks, let's do a review according to these, no more. Big smile
08.05.2020 17:26 # 13
Alicilik
[QUOTE = elsoberano] Thank you, let's do a review accordingly, no more. I'll put a cloth between the glass. "Big [/ QUOTE]
welcome, I hope it is easy solution.
I prefer hot silicon. The cloth can smell if it gets water
