Burnt smell and bankruptcy in the air conditioner |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » All Questions About Your Vehicle | |
| 08.05.2020 18:46 | # 1 |
kivanc01 |
| 08.05.2020 18:46 | # 2 |
Does the fan blow, but the air conditioner is not cooling? Or is the fan not blowing.
| 08.05.2020 18:46 | # 3 |
kivanc01 |
the fan does not blow at all. AC light is working.
| 08.05.2020 18:46 | # 4 |
the fan motor had coal, it was finished, two days ago the air conditioner was working, but it was not blowing inside, the master said so but in the meantime it started to work spontaneously again.
| 08.05.2020 18:46 | # 5 |
kivanc01 |
Did you smell before the glacier? mine was a very intense smell. i tried to open it 4-5 times even today but it did not come back.
| 08.05.2020 18:46 | # 6 |
kivanc01 |
I am in Iğdır. I am learning with the masters. That's why the problem is.
| 08.05.2020 18:46 | # 7 |
kivanc01 |
I couldn't find exactly where the engine was on the internet
| 08.05.2020 18:46 | # 8 |
The socket is gone. Either you will change the socket or the electrician will pull the line and bypass the socket. It takes care of you if you go to an auto electrician.
| 08.05.2020 18:46 | # 9 |
kivanc01 |
Let me investigate tomorrow, a good electrician. I searched for a good idea. Thank you. Is the socket under the wheel?
| 08.05.2020 18:46 | # 10 |
It is probably under the glove compartment in the 307s and probably in the same place in the 206s.
| 08.05.2020 18:46 | # 11 |
kivanc01 |
Okay, I'm thinking about looking at it tomorrow.
| 08.05.2020 18:46 | # 12 |
ahmed206 |
Fortunately it is not air conditioning, it is about 99% fan motor. You shouldn't keep a lot of money.
| 08.05.2020 18:46 | # 13 |
kivanc01 |
The friends took care of 50 TL for the event sockets. But it took a long time for the workmanship to be inserted and inserted in the console. It was laid on the new cable. Thank you I found the master, thank you.
