Burning Rear Fog Without Burning Front Fogs?
08.05.2020 16:10 # 1
What kind of application can be done for friends 206 to turn on the rear fog lamp before the front fog lights up? Berkay 2011-09-29 21:43:27
08.05.2020 16:10 # 2
Separate the button from the front and rear fog lamps where they meet at the On / Off button, handle or fuse and make a separate button, or a simpler fuse on-off button. But laborious work: (& nbsp; Alicangulpinar 2011-09-29 21:51:07
08.05.2020 16:10 # 3
EmRe26
Put a button between the cable leading to the front fog light and pull it into the cockpit. I think this is the simplest. When the button is on, the front fog lights up. Reviews
08.05.2020 16:10 # 4
tayfundoner
You can burn the rear fog by burning the front parks without burning the front fog.
08.05.2020 16:10 # 5
EmRe26
You know it wrong, maybe it may be the partner, but in our 206s, turning the selector lever one step, the front fog is burning, turning it back to the rear fog, but there are no separate burning places. & nbsp;
08.05.2020 16:10 # 6
tayfundoner
that time may be correct because the vehicles I used to burn the rear fog and front fog were separate separately. There is no fog in the partner. There is only rear fog. This already has to be in all vehicles. The front fog is only a standard equipment in the adventure model.
08.05.2020 16:10 # 7
When we turn the arm back to the biker in 307, we turn the arm backwards when we want to turn them back when we turn them back first, they end up first, this time only the backs are left
08.05.2020 16:10 # 8
EmRe26
we are not reversing at least 2002 & nbsp; model does not rotate at 206 xt: D not know if new models are reversed & nbsp;
08.05.2020 16:10 # 9
frtkck
Since there is no fog in front, when I turn the part marked with fog on the arm down one turn, my rear fog is burning, the subject is nice because I learned that the front fog will work from the same arm.
08.05.2020 16:10 # 10
berkay brother you will make a separate key to the back row most pressed
