Bumper tape vs painting
08.05.2020 16:05 # 1
deamod
I think if the friends did not throw the primer liner beautifully, I thought I had removed the bumper bands etc, I just took off the plastic liner, I guess I don't have any idea about the paint, I don't think it will be with any paint, and how do I find a paint in the color of the vehicle, how can I adjust the brightness? please :)
08.05.2020 16:05 # 2
34sea45
first of all, you need to be careful when removing plastics.
If you go to the industry with the color code of the Boyayada vehicle, they fill the spery boxes.
08.05.2020 16:05 # 3
deamod
So where do I learn the color code of my vehicle? I do not have the slightest information about that topic.
08.05.2020 16:05 # 4
34sea45
It should be sticky in the place where the writer lock is on the driver's door.
08.05.2020 16:05 # 5
deamod
So what do I have to do if the car was painted, so I don't know much about whether it is painted again, but if it was painted, is it complete?
08.05.2020 16:05 # 6
34sea45
Even if it is painted, it is the same color. If it is not sticky, you can learn the color code of the vehicle from the services.
08.05.2020 16:05 # 7
woshborn
You can see and understand the paint code from the picture on the sticker on the side of the left driver's door.
08.05.2020 16:05 # 8
metin
paint code opens the door of the driver and the door hinge says there. at least my 307 is there (:
I painted the door laths etc by myself. There is a detailed and illustrated expression in the forum. If you suspect that the vehicle has changed color, go to the painter in the industry, it has a wide color chart. get the closest one to the color of the vehicle from there, then press that color into the tube.
sand the part thoroughly and primer. then paint at least 2 kay. Make sure there is a windless environment and painting at least 30 cm.
Finally, if you varnished, the process is complete.
08.05.2020 16:05 # 9
deamod
industrial spray spray twill in varnish
08.05.2020 16:05 # 10
Burak07
[QUOTE = woshborn] You can see and understand the paint code from the picture on the sticker on the side of the left driver's door
very nice picture thanks
