Bumper and mirror painting
Homepage » PEUGEOT MODIFIED PLATFORM » How To
08.05.2020 18:36 # 1
IBRAHIM ASIL
materials
1: tool color coded spray paint 15 20tl spray varnish 20tl spray primer 15tl paste 15tl sandpaper finest 1 tl cake 7tl
(There is a special liquid for mirror bumper door handle to be painted for the first time auto painters satyo 10tl enough product that looks like silvery water in the pictures)
2: The surface to be painted is sanded and the dents are filled with paste, rubbing marks, etc., and left to dry.
3: After the paste has dried, excess flour of the paste is removed with sandpaper. When sanding, wet the sandpaper frequently and put a flat board underneath to create a wavelike image.
4: When the sanding is finished, apply the primer paint thinly in a layer of 4 to 3 cm from a distance of 15 cm.
5: After the primer is dry, sand the primer abundantly and sand the primer paint this time without wood. When the level is completely leveled, paint the area with paint coded fine 5 5 or even 7 times. After the process, there will be a matte appearance in the area you paint. After 24 hours (the most beautiful), sanding the paste you use with sandpaper you use while sanding (the most beautiful). The area you paint by pressing it will be like a glass.
Serkan 2014-06-11 20:42:48
08.05.2020 18:36 # 2
IBRAHIM ASIL
You can apply this with a special glue brush etc. that I mentioned above for mirrors and bumpers that will be painted for the first time without forgetting this product.
08.05.2020 18:36 # 3
emre_akdag
Good information. Thank you for your sharing :)
