Bulb recommendation
08.05.2020 14:06 # 1
Murat
My friends, I wanted to install xenon on my headlights, but I gave up because the headlights are lensless.
Buying and replacing white bulbs seemed like a better idea.
Which bulb do you recommend? I want white light.
My car's headlight type 206 new type transparent lensless H7 headlight.
I think it's H1 in fog.
08.05.2020 14:06 # 2
Onur
murat brother, if you don't put white bulbs on the fog, white light does not work in the fog, normal headlights have phillips white bulbs well they may be in my osmos I have osram nıght breaker not fully white but the night is illuminating very well.
08.05.2020 14:06 # 3
phillips diamond vısıon ..
08.05.2020 14:06 # 4
Onur
[QUOTE = EmRaH] phillips diamond vısıon .. [/ QUOTE]
08.05.2020 14:06 # 5
Murat
This bulb was pretty expensive emrah. 80 TL Shocked
08.05.2020 14:06 # 6
Murat
[QUOTE = horby37] murat brother better white light does not work in fog.
The headlights are bad when the white fog is yellow. we have to change both. Actually, he was good at the bulb price you said.
08.05.2020 14:06 # 7
hasimayaz
They sell enon for 100 - 150 liras. Keep the fog yellow
08.05.2020 14:06 # 8
Murat
[QUOTE = hasimayaz] They sell enon for 100 - 150 lira. Make the fog stay yellow [/ QUOTE]
Haşim brother, I order this, then. The price is fine. 6000 K. Or should I get 8000 K? http://www.hepsiburada.com/productdetails.aspx?categoryid=271585&productid=otelf7598
Why don't I wear it in the fog? The top is white and the bottom is yellow. When I open the mists, there will be a bad image.
08.05.2020 14:06 # 9
[QUOTE = Murat] [QUOTE = EmRaH] phillips diamond vısıon .. [/ QUOTE]
no two of 60-65 rubles
my friend is using 206 also 4 is no fading bangs nothing, there is cheap beeosan mtech but after 1 month the color changes
08.05.2020 14:06 # 10
Onur
[QUOTE = Murat] [QUOTE = horby37] murat brother better white light bulbs do not work in fog.
[/ QUOTE] Brother would be a bad image, but he would do his job in the fog.
08.05.2020 14:06 # 11
hasimayaz
[QUOTE = Murat] [QUOTE = hasimayaz] They sell enon for 100 - 150 liras. Make the fog stay yellow [/ QUOTE]
good price .. guaranteed. I think it is obvious that 8000k al enon. Those in me are yellow in my 8000 mists. You can not open the new status of Ankara unless you already need it, it is more correct to be yellow when you need it.
08.05.2020 14:06 # 12
Murat
[QUOTE = hasimayaz] [QUOTE = Murat] [QUOTE = hasimayaz] They sell enon for 100 - 150 liras. Make the fog stay yellow [/ QUOTE]
I understood it, brother. As you said, I now order 8000 ones.
Where is the bidet suitable for this xeno ballast? Can I do it alone.
08.05.2020 14:06 # 13
hasimayaz
[QUOTE = Murat] [QUOTE = hasimayaz] [QUOTE = Murat] [QUOTE = hasimayaz] They sell enon for 100 - 150 liras. Make the fog stay yellow [/ QUOTE]
Get black double-sided tape before installing, because they are durable because they are black.
No problem for the space on the left side, just paste it to the chassis right behind the headlight. but on the right side you have a bottleneck so ballast that will come under the brain Place a piece of sponge in between to prevent your brain from being damaged by this condition. wrap the fault ballast with electrical tape.
08.05.2020 14:06 # 14
Bursahasan
2001 roland garosum have what are their bulb types
08.05.2020 14:06 # 15
[QUOTE = Bursahasan] 2001 have roland garosum what are their bulb types [/ QUOTE]
Hodja, if your headlights are transparent, h7 - h1 or h1 - h1. the glass is h4.
08.05.2020 14:06 # 16
Bursahasan
Transparent ayfar brand short h7 long h1 midi side
08.05.2020 14:06 # 17
[QUOTE = Bursahasan] Transparent ayfar brand short h7 long h1 midi side [/ QUOTE]
headlights changed later, my teacher h7 - h7 should be.
