Bulb recommendation
29.05.2020 13:05 # 1
transform
Greetings to friends. I wanted to ask here because it is a job I do not understand much. I do not know how to buy. What bulb should I buy, what is the compatibility status, can you help if there is no trouble?
29.05.2020 13:57 # 2
And you can find the types of bulbs related to the vehicle in the link I contacted. http://public.servicebox.peugeot.com/APddb/zenon dipped beam is original or made later. If it was done later, you can buy led bulbs. The reason I recommend this according to shorts and fog is to be able to install it in the vehicle without cutting the cable. You can use bosh - philips as a light bulb brand. Since it is a new bulb, its illumination will be nice. You can use the reversing lamp and led bulbs in fog.
29.05.2020 14:04 # 3
transform
Thank you very much Soner. I guess I should have written a little bit. I think the standard bulbs are all over now, I wrote the list I plan to make :)
29.05.2020 14:17 # 4
okay then teacher. Exnon is definitely with a ballast. only led is appreciated. I recommend you to look at slim models like the link. otherwise the back cover does not close. https://urun.n11.com/led-far/ars-mini-led-xenon-h7-h1-h4-9005-9006-h11-h3-h27-8000lm-simsek-p352028671
29.05.2020 18:16 # 5
transform
thank you very much [QUOTE = sonerkyl] ok then teacher. Exnon is definitely with a ballast. only led is appreciated. I recommend you to look at slim models like the link. otherwise the back cover does not close. https://urun.n11.com/led-far/ars-mini-led-xenon-h7-h1-h4-9005-9006-h11-h3-h27-8000lm-simsek-p352028671[/quot A]
01.06.2020 10:06 # 6
whisky
Do not ... friends I bought ARS Mini Led did not light up the hand lamp. We rubbed a little while returning. Don't get tired as a mini led. then I went and bought Niken at the same values and provided much, much better lighting. It wasn't a mini so I changed the headlight rear covers so it's simple. Headlight tailgate headlights around 20 TL if the led bulb does not fit.
01.06.2020 10:06 # 7
whisky
01.06.2020 11:38 # 8
uzunca961
The cover is not a problem at 308, there is enough space. though I wore it from standard fan leds
