bugs after xenon to mists.
08.05.2020 14:51 # 1
BuRCaK
friends 2 days ago I had the xenon in the fog 8000 and the first start gave BRAKE FAULT, or brake failure. I closed the ignition, I opened it and it did not. I said that it is normal when the wheels are dismantled while Xenon is mounted. I burned the fog where I stopped that same evening and the handbrake was applied. HAND BRAKE FAULT, or handbrake error, was written on the screen. I closed it again, opened it, the contact did not repeat. There was no such problem before the xenon in the fog. I don't know if I will do it again today.
Why do you think it might have been?
8000 xenon in headlights
8000 xenon in fog
Amphi
these three are connected to a 60 amp battery and it doesn't lift the battery all?
08.05.2020 14:51 # 2
individual
If xenons are made in china, they may damage the electronic components of the vehicle since they are not put into magnetic field tests when leaving the production line.
Every factory xenon (hella, osram, denso, valeo etc ..) passes these tests.
These tests are not performed in Chinese goods, the result is already clear.
Also, if you had to wear 6000k at night, you could see the road at night.
Gülme
08.05.2020 14:51 # 3
BuRCaK
airbag fault and brake fault error when opened with fog off while on the move. but it's okay if I open the mists and set off before I move. I beg your pardon. I hope my Hashim will answer.
08.05.2020 14:51 # 4
If you don't get the xenon from us, it will be a bole :)
08.05.2020 14:51 # 5
tayfunyesilyurt
[QUOTE = EmRaH] If you don't get the xenons from us, it will be a bole :) [/ QUOTE]
Emrah is the most convenient if you set a xenon to 307 :)
I hope Burçak will solve the problem as soon as possible. It is clear that there is a problem in electricity distribution. I don't think it's from electromagnetic interference.
Greetings
08.05.2020 14:51 # 6
Japanese 130 TL :)
08.05.2020 14:51 # 7
H-a-d-i
Emrah, you know, Burçak was asking you xenon?
08.05.2020 14:51 # 8
individual
[QUOTE = typhoonyesilyurt] [QUOTE = EmRaH] If you don't get the xenon from us, it will be a bole :) [/ QUOTE]
Greetings
Actually, xenon is not a xenon kit.
headlight system. that is, the lens type.
The xenon kit used in the xenon or the bi-xenon is the same.
In the market, they usually call H4 types a bi-xenon but
Gülme
08.05.2020 14:51 # 9
tayfunyesilyurt
When I say bi xenon, I meant one xenon bro :)
08.05.2020 14:51 # 10
individual
[QUOTE = tayfunyesilyurt] When I say bi xenon, I meant one xenon bro:) [/ QUOTE]
Sırıtma
08.05.2020 14:51 # 11
deniz_206
burçak same trouble, wardi fog was close to me, the fault lights are on right now and the vehicle has a stop stop, there is an apparatus called capacitor, you have to install it from 2 sides voltage stabilizer.
08.05.2020 14:51 # 12
Sinan
No need for apparatus. I got it stuck, no problem. I am very satisfied. They did not even remove the rubber mastic when installing it. This is due to xenon.
08.05.2020 14:51 # 13
BuRCaK
I am really wondering if you would have received Emrah from you and would have returned my money again. Sırıtma
I also wanted the price of xenon issues in different topics, but you did not return, brother. Anyways. If I open the mists in motion, the malfunction lamp is on. No problem if I turn fog on and then move before moving the vehicle.
Deniz Where did you get this capacitor, how do we install it on my vehicle?
08.05.2020 14:51 # 14
walla xenon price I want you, I also wrote about it was also about it :) don't worry there would be any return :) plug in the apparatus that the sea says fix
08.05.2020 14:51 # 15
kitay
Hi friends, I wanted to have mists, but the problem is appearing, I am a person who does not like to use perfect night for short 3 months ago.
08.05.2020 14:51 # 16
sound stream is used with us
08.05.2020 14:51 # 17
MirakGTI
I was in the old 206 as well, and in the fog and fog there was no such error.
08.05.2020 14:51 # 18
BuRCaK
Any other idea?
08.05.2020 14:51 # 19
hasimayaz
Ballasts are troublesome .. no further explanation. I think it will take off without damaging the vehicle. Also, does the xenon become a fog? Let it be yellow.
08.05.2020 14:51 # 20
deniz_206
[QUOTE = BuRÇaK] I am really wondering if you could get my money back if Emrah bought it from you again Sırıtma
In auto electrical and television repairers, the current is balanced by the current woltage, and the fault light is not on yet.
Page : / 2
