BSI WATER PROBLEM
08.05.2020 20:44 # 1
SevkicanBalci
FRIENDS GOOD FORUM FOR 2004 2004 MODEL 307 VEHICLES HAVE BEEN CHANGED THE BRAIN OF ITS WATER BECAUSE I HAVE NOT FINDED THE WATER, BECAUSE I RECEIVED THE WATER, I HAVE BEEN RECEIVED THIS TIME, I HAVE ALMOUGH I PURCHASED THIS TIME, I HAVE ALSO HAVE BEEN CLEANED AND WAS ALSO GOT I HAVE TO BE CLEANED AND WAS MORE THAN 2 TIMES AND I WOULD LIKE TO CLEAN THAT I HAVE BEEN CLEANED AND WERE ALSO HAVE BEEN CLEANED TO GET 2 HIGHLIGHTS. THEY SAID THE COMPUTER POSSIBLE THE FUEL PUMP SENSOR FAILURE. THE VEHICLE SENDER DOES NOT REMOVE THE CIRCUIT BUT IS WORKING IN SINGLESS SINGLE STARTER FOR 2 3 DAYS.
08.05.2020 20:44 # 2
crazysado
If the car has an audio system, check the location inside the hood where the amp cable from the battery is pulled. There was a relative of a 307 in the car. There was a sound system before.
08.05.2020 20:44 # 3
SevkicanBalci
I looked at the place you said when you first took water, it was silicone. I siliconed the bottom of the cables coming to BSI from the inside when it gets water again. There is no water intake problem right now, but after the 2nd water intake, this problem has occurred.
