bsi reset & switch adaptation?
08.05.2020 17:53 # 1
error
Hi friends, the battery of the car has just changed, but the procedure has not been followed, the left window does not close, but the sunroof right window and the mirrors close, even though I hold the lock button from the outside of the car.
how were we doing this adaptation?
error 2013-08-17 22:33:25
08.05.2020 17:53 # 2
E.B
same problem exists in me ... update
08.05.2020 17:53 # 3
error
And once I tried to close the windows from inside, the rear-view mirrors were also closed, it would not have been done before. I hope nothing has happened. Shocked
08.05.2020 17:53 # 4
error
up
08.05.2020 17:53 # 5
error
thanks honor i will try in the morning Handshake
08.05.2020 17:53 # 6
error
Unfortunately, I tried to say the honor first, the result did not change. When I try to try the second one, when I turn the key and press the lock button, the locking sound immediately emerges. The room did not change much.
In other words, when I hold down the lock button, the driver closes everywhere except the glass without problems, I just can't close a window, I wonder if I disassemble the battery at night and reset it in the morning.
or what else would you suggest?
error 2013-08-19 19:33:39
08.05.2020 17:53 # 7
adali
[QUOTE = onurazgin] Remote control synchronization;
1-Turn off the ignition.
2-Turn the ignition back on.
3-Immediately press the A (lock key) button for a few seconds.
4-Turn off the ignition and remove the key from the contact. The remote control is working again.
It is necessary to introduce the control to the vehicle after the control battery replacement or for any reason when the vehicle's control opens and closes the vehicle's doors. This is called control synchronization.
Another synchronization is;
by inserting our key into the keyhole on the driver's side, we turn it in the locking direction. While keeping it rotated in the locking direction, we also hold down the control lock button. You will hear a clicking sound from the door lock when held down for about 5 seconds. Remove the key And
press the door open button on the remote. That's how your key was introduced to your vehicle again.
Usually, this is done to introduce the incoming key to the vehicle when a new key is ordered in the services. Sometimes this may be necessary when you replace the control battery. "
08.05.2020 17:53 # 8
adali
God bless you The control was not working for about 6 months. I did what you wrote.
08.05.2020 17:53 # 9
BerkeKarayel
pull the windows up to 10 sec in the accessory mode from the joystick
08.05.2020 17:53 # 10
error
[QUOTE = BerkeKarayel] pull the windows up in the accessory mode for 10 seconds [/ QUOTE]
you are great master solved Smile
Thanks to everyone who contributed ...
error 2013-08-20 19:29:47
08.05.2020 17:53 # 11
error
Since the tape lighter socket etc. is active in the first stage of the switch, some prefer to call this stage as the accessory location, but I tried the suggestion of each one while the vehicle was working.
In fact, the information that can not be searched for, for example, has not been able to find this solution, so our friend had to use this tool for 6 months.
top topic or something like "tricks of vehicles"
error 2013-08-20 22:15:10
08.05.2020 17:53 # 12
BerkeKarayel
[QUOTE = errör] [QUOTE = BerkeKarayel] Pull the windows up for 10 seconds in the accessory mode from the joystick [/ QUOTE]
I thank you :)
08.05.2020 17:53 # 13
EnSoNiQ
I could not turn off the sunroff with a remote control. Does anyone know the solution? ENSONIQ 2013-09-04 21:47:29
