BSI REQUIRES BRAIN
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 406
08.05.2020 19:19 # 1
muharrem123
the indicators are turning off engine immobilizer gives fault error I don't know exactly but the indicator is my brain how much the price is the brain brain bsi said the brain is working for now but said it needs to change muharrem123 2015-06-29 11:31:01
08.05.2020 19:19 # 2
scorpion_enis
I can recommend a good master in Izmir if you want specially. I hope you enjoy your vehicle that gets rid of its problems.
08.05.2020 19:19 # 3
themurat54
God help me brother
08.05.2020 19:19 # 4
demir2001
Look at the vehicle's electronic panel fuses in series
08.05.2020 19:19 # 5
Canberk35
Indicators turn off while the vehicle is running and ABS, airbag etc. It usually happens that the vehicle is not getting enough voltage from the battery. If possible, you can replace the batteries with an acquaintance and experiment. (Of course, by paying attention to his amps :) I am also in Izmir. If you wish, I can advise you on special service-master in Izmir. I have no doubt that they will be interested and will solve your problems. Get well soon.
08.05.2020 19:19 # 6
hsnsnl
hello, i recommend iztek peugeot, i have friends there, i think they will fade my name and help if you want ..
08.05.2020 19:19 # 7
muharrem123
You are right, the problem is that I changed the battery from it, it was 1 year or so, the battery on it was 60 amper electrician, 75 amper was installed yesterday, I put 60 amp on the back, the problem has been solved thank you. Big smileBig smileBig smileBig smileBig smileBig smileBig smileClapClapClapClapClapClap
08.05.2020 19:19 # 8
muharrem123
Thank you for your interest muharrem123 2015-06-20 09:48:26
08.05.2020 19:19 # 9
muharrem123
EASY TOGET my friends, I stayed on the road the other day, I started the car in the morning, I traveled 5 km and stopped the car, started writing engine immobilizer fault on the trip computer, and then I left the battery poles, I waited for a while and then I put it back and the car worked and then stopped after a little more engaging with 6 industry also disconnect any cables We went to beyinci`y brains connected to a computer or something something they did but I got something no 3 day problems had been very nice but after the car he said again, engine immobilizer fault and what problems did it stayed
I would be happy if you help
08.05.2020 19:19 # 10
Canberk35
Connecting to the vehicle through the obd port and finding out what the error actually is takes you to the right solution. As it wrote, the error is immobilizer error, i.e. the condition that the vehicle and key do not match If you have a spare key with an immobilizer chip, try using it with it. However, the error may not be caused by the key or immobilizer. If there is a condition that makes the vehicle brain short-circuited, it may be the reason. No need to check.
6. If you go to the service that I sent you with a private message while you are in industry or if you reach the phone number on their site and explain your problem, the master will help you as much as he can. Thumbs Up
08.05.2020 19:19 # 11
muharrem123
I went to the service you said, I am not satisfied, now they call the brain software again, I am waiting.
08.05.2020 19:19 # 12
Canberk35
I hope it will be resolved in a short time and it will not cost you a lot, teacher. Get well soon.
08.05.2020 19:19 # 13
peugeot murat
When you go to the electronics shop, you can call the master, the teacher, and he will call me.
08.05.2020 19:19 # 14
muharrem123
Is this murat buca in the industry or when is the brain man named adnan, because I was there?
08.05.2020 19:19 # 15
muharrem123
08.05.2020 19:19 # 16
peugeot murat
Yeah
08.05.2020 19:19 # 17
muharrem123
08.05.2020 19:19 # 18
peugeot murat
Yeah
08.05.2020 19:19 # 19
muharrem123
08.05.2020 19:19 # 20
muharrem123
I came over there 06 plate vehicle was on the front otherwise but the flow is out on the road you are that murat are you murat
Page : / 2
