broken hose
08.05.2020 18:53 # 1
omera
greetings friends. I noticed this morning in my vehicle 2001 206 xt- a gasoline hose coming out of the throat throttle, remains broken. not exactly curved. as if bent. I didn't understand the original like that. I couldn't take a picture of it, I'll take it sometime. The air passage is narrow, I wonder if it will cause trouble?
08.05.2020 18:53 # 2
herry
It would be more healthy if it is a photo. air filter or oil drain hose.
08.05.2020 18:53 # 3
omera
I add the photo .. if I loosen that handcuffs, I wonder if ...
08.05.2020 18:53 # 4
omera
Where are the masters?
08.05.2020 18:53 # 5
peugeotefe
It does not cause any trouble from that hose, your car is an oil vapor hose. If the image disturbs you, you better fix it for comfort
08.05.2020 18:53 # 6
Ali1905
I think the oil vapor hose is the upper one with the yellow clip on the top, the vacuum or petrol return system hose you marked
08.05.2020 18:53 # 7
fætih
oil steam hose. the oil decreases the vehicle but it doesn't decrease much ...
08.05.2020 18:53 # 8
peugeotefe
[QUOTE = Ali1905] oil vapor hose with top yellow end hose with hose, vacuum or petrol return system hose you marked [/ QUOTE]
Please do not mislead the friend
1. 206 gasoline engines have no vacuum.
2. gasoline return system does not go through butterfly throat
08.05.2020 18:53 # 9
omera
current friends
08.05.2020 18:53 # 10
Emask
my friend, I couldn't understand what hose it was, but it is certain that it will block the flow of something. I recommend you to look for a way to fix it.
