broken gear knob replacement
08.05.2020 19:53 # 1
x571
Hi
I think the gear knob was broken. It remained in the hand: D How do we change this? How can I do it at home? according to what we get when buying a new one?
08.05.2020 19:53 # 2
samet206
You take the new one and put it on top of it, on the white plastic stick. But at the bottom of it, it looks like it is divided into two.
08.05.2020 19:53 # 3
x571
x571 2016-07-03 14:29:00
08.05.2020 19:53 # 4
x571
[QUOTE = samet206] You take a new one and put it on top of it, on top of the white plastic stick, but at the bottom of it, it looks like it is divided into two, it looks like it is divided into two.
It is necessary to remove the black piece like the remaining bracelet in the white piece. I did it left and right, but he doesn't want to get hurt. is there any direction we will translate it to? Does it matter? Would it be a problem if we used a wrench? would we hurt another place?
08.05.2020 19:53 # 5
x571
I looked at a few videos on the net. They also remove the bellows for citroen. do we have to do something like that?
08.05.2020 19:53 # 6
samet206
Well, I can not describe it as a direct one, which I disassembled the bellows when the galba came from the edges. I am not sure of the bellows. Be careful not to break it.
08.05.2020 19:53 # 7
x571
[QUOTE = samet206] Well, I can not describe it directly, I can not describe the bellows, the galba came from the sides of the room. Be careful not to break the white plastic rod through which it passes.
thanks youtube, there was a plastic american clamp. i think we cut it :) thanks for your interest
