Breking Fault Alert
08.05.2020 20:55 # 1
74emre
As I mentioned in the title, my vehicle gives a warning of breking foul and stops. When I press the horn, the tachometer drops. When I make the slector, it gives a breking fault warning and my vehicle stops. Now I started to hate this vehicle. Previously, there were such problems, it was said from the charge dyno and the conjectors, and it changed and improved. Now let's do what the same problem started again. I would be happy if you help
08.05.2020 20:55 # 2
Selcuk55
No matter when the conjunctors have changed, unfortunately the conjunctor needs to change.
08.05.2020 20:55 # 3
74emre
The connector was not compatible in any way. The charging dynamo had completely changed.
08.05.2020 20:55 # 4
Remove the bsi or fuse box and have a nice check. The problem is an electrical problem. In addition, the vehicle was equipped with additional electrical equipment, such as the exnon sound system.
08.05.2020 20:55 # 5
74emre
No, sir, in addition, nothing was stuck. Everything in the vehicle is original.
08.05.2020 20:55 # 6
denizzined
The same fault you mentioned is also written in my vehicle, but it is not in motion, I stopped the vehicle and stopped the ignition completely, it gave Brekaking fault abs fault errors. They said, let's look at the brake sensor, but I still recommend you to show it to a good electric master, the problem is a little different.
08.05.2020 20:55 # 7
74emre
Thank you
