Breaking stops 20-30 seconds after Lpg
30.03.2021 15:17 # 1
Karacocuk24
Hello, after 40-50 meters after starting in the morning when the vehicle is cold, the idle rises a little and then it stops and stops if I act early and switch to gasoline, it will improve if I go to gasoline 300-500 meters and it continues as if there is no problem when I stop and start again in the day. No, I went to lpg and changed 2 filters, I made a new setting and I put lpg additive, the master said the spark plug and the coil did not look at a thousand km. The variable coil may be, but if the coil is, maybe it will not stall in the gasoline, but when it is in lpg, it should constantly misfire, the idling motor and the idling motor and Is there a possibility of a throttle?
30.03.2021 19:08 # 2
muzzy35
Go to a lpg master and have the transition temperature to lpg 40 or 45
30.03.2021 22:45 # 3
Karacocuk24
[QUOTE = muzzy35] I go to a lpg master and have the transition heat to lpg 40 or 45 [/ QUOTE] I'm already using 45
30.03.2021 22:49 # 4
muzzy35
I have experienced the same lpg master let's raise the degree to LPG is very low, he said it passed, thank God it is a simple thing, my brother, get well soon.
30.03.2021 23:30 # 5
Karacocuk24
[QUOTE = muzzy35] I experienced the same lpg master Let's raise the transition level to lpg is very low.
Thanks
15.06.2021 21:35 # 6
Karacocuk24
Friends, I solved my problem, after these complaints, there were situations such as giving the gas and stopping by itself until it warmed up.
Peugeot Forums - Peugeot Fan Club © 2025
