break fluid level low 307
08.05.2020 16:59 # 1
salihata
"break fluid level low" warning appeared on the screen while my friends started this morning. What is the reason for this malfunction? what is this warning? are there any friends who can help?
08.05.2020 16:59 # 2
fexzi
There is a decrease in your brake fluid, so check as soon as possible, brake is a very important equipment.
08.05.2020 16:59 # 3
salihata
[QUOTE = fexzi] There is a decrease in your brake fluid, so check it as soon as possible, the brake is a very important equipment. Can I add hydraulics or add a master?
08.05.2020 16:59 # 4
[QUOTE = salihata] yes, my brake fluid does not hold the finished brakes completely, can I add hydraulics or add a master? [/ QUOTE]
Brake fluid is not something that will decrease over time. Have a look at whether there is a leg if you want.
08.05.2020 16:59 # 5
fexzi
[QUOTE = koliva] [QUOTE = salihata] yes, my brake fluid does not hold the finished brakes completely, can I add hydraulics or add a master? [/ QUOTE]
Brake fluid is not something that will decrease over time. If you want, have a look at it.
Have the brake hoses checked by joining .
08.05.2020 16:59 # 6
salihata
[QUOTE = fexzi] [QUOTE = koliva] [QUOTE = salihata] yes, my brake fluid does not hold the finished brakes completely, can I add hydraulics or add a master? [/ QUOTE]
Have the brake hoses checked by joining . thank you. What if you can give me any brand, how much do I need to put in one?
08.05.2020 16:59 # 7
monur
I think instead of completing the brake fluid, check for the leaks and have a look at your pads, probably your pads are exhausted. As the pad becomes worn, the piston that presses the pads on the disc remains ahead and lowers the brake hydraulic level. & Nbsp; "Wink"
08.05.2020 16:59 # 8
metin
As brake fluid linings and discs get thinner, their level decreases accordingly. When you renew the disc and pad, it returns to the old level again. & Nbsp;
If your disc and pads are low in wear and the oil level is low, there may be a leak in the system. Have it checked as soon as possible.
08.05.2020 17:00 # 9
salihata
[QUOTE = text] brake fluid linings and discs decrease as their levels get thinner. When you renew the disc and pad, it returns to the old level again. & Nbsp;
If your disc and pads are low in wear and the oil level is low, there may be a leak in the system. Have it checked as soon as possible. He said, but while driving the vehicle, there was sound coming from the disks, it is best to take the vehicle to a brake pad service.
08.05.2020 17:00 # 10
salihata
[QUOTE = monur] I think instead of completing the brake fluid, check for the leaks and have a look at your pads, probably your pads are exhausted. As the pad becomes worn, the piston that presses the pads on the disc remains ahead and lowers the brake hydraulic level. & Nbsp; "Wink" [/ QUOTE ]
the pads are zero, I put brake oil today and I looked at the car and pumped the brake as I said, there is a leak under the vehicle as there is a leak & nbsp; "Cry"
08.05.2020 17:00 # 11
Gbulbulyay
I have the same problem on my 307 vehicle. They said that the linings were looked solid. They said the rear brake center will change. They issued a price of 700 TL. I have been using it for 2 months and the brake goes down to the very bottom. The vehicle is still standing.
