Brake Systems in Our Vehicles
08.05.2020 15:21 # 1
BRAKES
It is used to fix the vehicle with the parking brake on the vehicle. If the parking brake is broken, the parking brake does not hold. If the handbrake is forgotten and the road continues, the drums become hot and do not hold the brake.
There are 3 types of brakes on the vehicle:
Engine brake (compression brake)
-Foot brake
-Handbrake
Foot brake is of 3 types:
Hydraulic brake
-Pneumatic brake
Mixed brake
Some parts of the brake system are:
-Brake pedal
-Center pump
Brake pipes
Wheel rollers
-Brake disc
-The brake lining
they -Kampan
Brake adjustment systems
An air brake vehicle has an air cylinder and a compressor in addition to the upper ones.
The advantages of ABS braking are that it does not distort steering while braking and shortens braking distance.
If the vehicle's speed does not decrease despite braking, the brake fluid is absent or decreased, even the braking settings may be slow. It may have leaked oil into the brake system. There may be a leak in the brake system.
If the handbrake is left in cold weather, the brake pads will freeze and stick.
If the decrease in the hydraulic braking system is supplemented with hydraulic oil.
When the foot brake is applied, the front and rear wheels stop together.
If the vehicle is operating but cannot be moved , the parking brake may be applied .
The vehicle may be damaged drum brake settings have been overheated.
If one of the front tires is new and the old one brakes, the vehicle pulls aside .
If the engine is stopped while moving in a Westinghouse-type brake car, it will never brake.
If the air pressure gauge does not show pressure in the vehicle with air brake, the vehicle cannot be lifted from where it is.
08.05.2020 15:21 # 2
GiTaRRa
nice sharing tşk
