Brake Pedal Vibration
08.05.2020 16:42 # 1
carantinas
Hello friends, I had a 15 "rim tire on my vehicle at night, I put a flash on the rear wheels as well, I didn't have rims because of rubbing. But now I have a problem. The brake pedal vibrates very badly when I press the brake. I don't have a problem with the car when there is a rim, are they trying to send me? & nbsp; what is the reason? & nbsp; from balance or discs. >
08.05.2020 16:42 # 2
toga406
If the discs are not skewed, they must be made of pads.
08.05.2020 16:42 # 3
istanbullu_3886
distortion of discs hits the brake as it vibrates or kick the pedal
08.05.2020 16:42 # 4
carantinas
I understood, but as I said, there was no problem with the 13 "rim, and I got it the next day. When I first got the tire, I got a kick, so I got a kick. could it be due to bending carantinas 2012-04-14 20:56:23
08.05.2020 16:42 # 5
istanbullu_3886
Even if it is made of tires or rims on the normal road, the vehicle should be buckled or hit the steering wheel.
08.05.2020 16:42 # 6
dukenukem82
Rot balance once
08.05.2020 16:42 # 7
carantinas
Thank you for the answers. So how much does disk turning cost?
08.05.2020 16:42 # 8
racer50
disk distortion may happen at once, for example, sudden heat changes may occur when the disks are hot, or incorrect brake timing when coming to the coffers?
08.05.2020 16:42 # 9
istanbullu_3886
[QUOTE = carantinas] thank you for the answers. Well, how much does disk turning cost?
08.05.2020 16:42 # 10
metin
The reason for the vibration is from the discs, and after 120, the steering vibration is from the balances.
