Brake pedal softening
08.05.2020 21:16 # 1
cege
meehab are. When I pressed the brake pedal 5 months ago, it had softened down to the floor. I immediately took it to a master, changed the headquarters, and the problem was fixed, but still it was not as before. I used it that way for the last 10 days until I had the same problem again. This time, it does not soften and descend immediately, but as it waits on the ramps in the lights, it slowly goes down. They said from the oil, they changed the oil, the air was removed, but it did not improve. What do you think is the problem? A master said the front center and the back center will change. I tried on the ramp. If I did not misunderstand when the pedal is softening, the car squeaks and the brake is released. It sounds like it came from behind. I am waiting for your help if you have experienced friends. I have spent more than 5 thousand in the last 3 months. I am overwhelmed by my years. He is trying to pluck his coyote, regardless of his age. I ask for help cega 2019-07-13 20:23:27
08.05.2020 21:16 # 2
x571
[QUOTE = CEG] meehab alarm. When I pressed the brake pedal 5 months ago, it had softened down to the floor. I immediately took it to a master, changed the headquarters, and the problem was fixed, but still it was not as before. I used it that way for the last 10 days until I had the same problem again. This time, it does not soften and descend immediately, but as it waits on the ramps in the lights, it slowly goes down. They said from the oil, they changed the oil, the air was removed, but it did not improve. What do you think is the problem? A master said the front center and the back center will change. I tried on the ramp. If I did not misunderstand when the pedal is softening, the car squeaks and the brake is released. It sounds like it came from behind. I am waiting for your help if you have experienced friends. I have spent more than 5 thousand in the last 3 months. I am overwhelmed by my years. He is trying to pluck his coyote, regardless of his age. I ask for help [/ QUOTE]
This is not something that will come from fat. There is a malfunction in the system. When the oil misses, the pedal goes down the floor. Nothing of 5 thousand. The man will look. Brake center, cylinder, brake hoses will change and will end. These are not such expensive things. The last brake center was 30 pounds in the industry.
08.05.2020 21:16 # 3
erendoqru06
I was afraid when I was reading my brother, look at the hoses, etc., follow that work, find a solid braker, no trouble.
08.05.2020 21:16 # 4
sozuak
Pull the vehicle to a clean place and push and release the brake while the engine is running. Wait 10-15 minutes, take the car forward and see if there is an oil leak.
Also check the hydraulic container in level. If there is excessive level loss, the relevant sensor will fail, but braked work.
My braking performance was very low. No leak, no fault record. Pads do not end easily due to the automatic gear. Discs changed completely 2-3 years ago, etc.
Westinghouse is from the valve, my friend said, I changed it, he was missing the valve, but it still did not improve. I said let me check that westinghouse hose, the engine melted into a metal part, melting both the manifold vacuum to the valve and causing a slight manifold leak. I clamped the hose together and positioned it away from the hot surface. If the new one had not been on the market, I would have replaced it. I had a slight collision twice due to the brake so I was leaving a lot of distance with me because sometimes the brake was good and sometimes very bad. Nobody has found any problem, unfortunately, nobody thought of disconnecting the hose.
