Brake Lights Are Not On :( muş
08.05.2020 15:58 # 1
ultrAzrail
Hello friends,
When I came home in the evening, I slowed down and stopped at the red light.When I stopped, there was a bitter brake sound from behind, and a little bit of a thrust to me. noluyo or something die, thank you brother did not send the situation officer we sent this officer. Why does this light not burn? I would be glad if you help ....
08.05.2020 15:58 # 2
metin
Check the bulbs first, but if the bulbs are intact, the brake sensor is malfunctioning.
08.05.2020 15:58 # 3
ultrAzrail
[QUOTE = text]
No one is burning :) Heee then forever industry
08.05.2020 15:58 # 4
metin
If you are a client, then it should be 20 TL and you can change it for yourself. Show it to an electrician.
We would appreciate if you write the model engine volume, fuel type equipment etc. in the signature part.
08.05.2020 15:58 # 5
ultrAzrail
Thank you. Let me take a look tomorrow.
08.05.2020 15:58 # 6
vbmaster
My teacher, take a hand under the pesal, a simple mechanism is attached to your hand ...
08.05.2020 15:58 # 7
tigerland
Check your fuses There are 2 fuses for the brake lights. If there is no problem, 4 bottomless bulbs and 2 stop lamp bulbs are burned out, it is impossible to burn them at the same time. I think the insurance case: S
08.05.2020 15:58 # 8
It must have 10 Amp F11 and F12 fuses. As a priority job, you should start by checking the soundness of the fuses.
08.05.2020 15:58 # 9
The brake pedal is stuck there, my brother, sometimes mine never faded, I got stuck there, it got better, get a hand before you go to the industry.
08.05.2020 15:58 # 10
check the bulbs first, then check the fuse, if not, either the brake sensor or the chassis in one place ..
08.05.2020 15:58 # 11
dextermeytoo
I came to my head last night, the brake lights are not on, all three at once. I couldn't go to industry yet.
08.05.2020 15:58 # 12
Ozgur
I think the problem is with the brake sensor.
I bought it from the service last year, and it is very simple. It has a price of 15 TL.
08.05.2020 15:58 # 13
You can change the insurance or insurance policy yourself. both of them are very easy htasay 2011-10-22 17:53:23
