Brake Light
08.05.2020 14:09 # 1
shamed
The brake light is not lit. They said the brake sleeve is faulty. What is this?
08.05.2020 14:09 # 2
Murat
The auto electrician takes care of it in 10 minutes.
08.05.2020 14:09 # 3
FTH
15 20 days ago I bought it for 15 TL Sinan brother even you wear it just above the brake pedal quiksilver 2010-01-19 13:43:15
08.05.2020 14:09 # 4
shamed
thanks
08.05.2020 14:09 # 5
deniz_206
samet you sell brother let's get that car gti 106 :) :)
08.05.2020 14:09 # 6
slowmotion
Get well soon
I hope you get it right now
08.05.2020 14:09 # 7
hasimayaz
Peugeot 206 Brake Switch Repair & Replacement
Tools
- Thin screwdriver set
- Oil-free Philips Contact Cleaner (blue)
- Philips spray oil (red)
- fine sandpaper
- Multimeter
- Side Chisel
1. We separate the foot from the foot at the bottom of the brake pedal. (by turning counterclockwise)
2. We disconnect the electrical connector.
3. We cut the nail into two by freeing it from your nails.
4. We remove the contact mechanism from the inside.
5. We clean the oxidized contacts with blue philips spray. We bend it slightly by hardening. If the plastics on the nail feet have slipped, we put them in place.
6. Lightly lubricate the spring mechanism.
07. We reunite the client with his nails again. We check the contacts with the multimeter. The two connector circuits on the left will be open and the other two connector circuits will be closed, otherwise the opposite will occur when you press the client.
08. We lock the spring by adjusting the red locking tab as shown in the figure.
09. We open the height adjustment well and put it in the last position. (the red lock will automatically throw and release the spring when it enters the insertion slot)
10. While holding the pedal to stop at its uppermost position, we push the sensor towards its seat. The height bar will come in with a crunch. we see that the red lock releases the spring by turning it clockwise when it is fully seated in its slot. We finish the process by connecting the electrical connector.
VERY IMPORTANT NOTICE: BRAKE LAMPS ARE HIGH IMPORTANCE SAFETY. DON'T THINK THAT THE REPENDENT REPAIR IS UNLOCKED, BECAUSE THE NEW GUARD'S PRICE IS 20 TL. THE PURPOSE OF THE ARTICLE IS TO SUPPORT YOU TO TAKE YOU TO THE NEAREST SERVICE WHEN YOU REMAIN ON THE LONG WAY OR WITHOUT COPY.
Haşim Ayaz ( hasimayaz@gmail.com )
08.05.2020 14:09 # 8
FTH
You did SHOW again, health for my master ...
08.05.2020 14:09 # 9
shamed
walla I just looked at the working headlights but I will change the brake switch
08.05.2020 14:09 # 10
Carmania
Haşim master, you are halal or you are in the lead roles again Thumbs Up Pt is proud of you :)
08.05.2020 14:09 # 11
Murat
Brother Hasim, you did your show again. good job.
08.05.2020 14:09 # 12
Can Duzyatan
This is called sharing and solidarity. Gülme
(I don't know if you made the shots, but if it belongs to you, the camera date setting appears in 2005, correct it, if you want the camera setting Gülme )
Can Düzyatan 2010-01-19 22:18:46
08.05.2020 14:09 # 13
Celalettin
Believe there is no such technical sharing in any forum.Bravvo be hasim brother.1 number ...
08.05.2020 14:09 # 14
Aytac
I swear that I was sick. A very good expression .. Congratulations ..!
08.05.2020 14:09 # 15
hasimayaz
[QUOTE = Can Düzyatan] This is called sharing and cooperation.Bravo Haşim Gülme
The machine keysmart is a hard machine, brother .. When the battery is removed, history flies .. Bidet makes it close.
08.05.2020 14:09 # 16
shamed
thank you hashim
