Brake hydraulic replacement
08.05.2020 20:38 # 1
OguzhanKucuk61
After the problem I had recently, the brake center was changed and the missing hydraulic was completed. I just came across a piece of information. When different types of hydraulic oils such as old and new mix, they lose their effect.
I want to completely drain the brake fluid and replace it with dot4.
After all, the problem that I had fresh didn't come to joke. How can I completely drain the brake fluid?
08.05.2020 20:38 # 2
ggitaristt
You will pour the new hydraulics from the top oil cap and remove the records from each of the wheels in order.
But I think there is no need, if the previous oil is dot4, there will be no problem.
08.05.2020 20:38 # 3
OguzhanKucuk61
There is no problem with the pedal and no problem with its stance. In both of them, the dot 4 added a master open hydraulic oil after the brake Center replacement. I said it was Dot4. I don't know, no problem
08.05.2020 20:38 # 4
x571
[QUOTE = OguzhanKucuk61] There is no problem with the pedal and no problem with its stance. In both of them, the dot 4 added a master open hydraulic oil after the brake Center replacement. I said it was Dot4. I don't know, don't worry [/ QUOTE]
Nothing matters anyway. I will fix it on youtube.
08.05.2020 20:38 # 5
OguzhanKucuk61
[QUOTE = x571] [QUOTE = OguzhanKucuk61] There is no problem with the pedal and no problem with its stance. In both of them, the dot 4 added a master open hydraulic oil after the brake Center replacement. I said it was Dot4. I don't know, don't worry [/ QUOTE]
When the customer becomes an intermediary, they do it carefully if it is their own intermediary. I will look at the channel, thank you
