Brake hoses
08.05.2020 17:00 # 1
kirmizi306
Hello friends.
Is there a certain time for the vehicle's brake hoses to change? We will go on a long journey tomorrow. I'm afraid, because we're going to go with a family of 5. discs-pads, timing belt-ball, spark plug-spark plug cable, filter etc. all had changed. Is there any place I should look at? otherwise, it would have gone away. Thanks in advance for your help.
08.05.2020 17:00 # 2
Although maintenance is new, there is a possibility of problems, after all, these are machines. Problems can sometimes arise even in new parts. I think it will not be anything if you travel slowly, cautiously and by obeying the traffic rules without leaving the precaution. Keep your heart fresh. Not if you travel with the thought that it will be out of order. Have a good trip now. By which way is Yon, by the way?
08.05.2020 17:00 # 3
kirmizi306
Thank you, my teacher.
08.05.2020 17:00 # 4
falan
brake hoses must be 10 lira or something .. & nbsp; change time half an hour .. & nbsp; I think you can keep it in mind without changing it .. because it is a piece of oil that passes through it .. In case of oil leakage, it may cause a problem in hydraulics ...
