brake hardening at first start |
| 08.05.2020 16:33 | # 1 |
| 08.05.2020 16:33 | # 2 |
the same problem is present in me for 2 weeks, sometimes it resolves sometimes it continues. I would have experienced pain that the brake did not hold. the road was empty I could escape. :(
| 08.05.2020 16:33 | # 3 |
Check your westinghouse suction pipe, clamps, joints for cracking, breakage, etc. There must be a valve. The forecast expires pressure from somewhere in the westhghouse (it may be from what I said above) The car can only regain pressure after a while the car is running. hard when you press the brake. |
| 08.05.2020 16:33 | # 4 |
I recommend you to have the brake system checked in detail & nbsp; Because it is vital, I say don't waste time. |
| 08.05.2020 16:33 | # 5 |
Then & nbsp; & nbsp; westinghouse & nbsp; and we will look at the pipes, thanks guys.
| 08.05.2020 16:33 | # 6 |
[QUOTE = dukenukem82] Then & nbsp; & nbsp; westinghouse & nbsp; and we will look at the pipes, thanks guys. [/ QUOTE] < div> Exactly. Thank you.
| 08.05.2020 16:33 | # 7 |
[QUOTE = 06ÖGGR06] I recommend you to have the brake system checked in detail & nbsp; Because it is vital, I say don't waste time. The most important part of the car is its brakes. .Motor does not kill, but kills without brake.
