Brake hardening
08.05.2020 15:30 # 1
freestar206
When I press the brake while friends are watching in my car sometimes the brake hardens and swells, as a result, it does not hold the brake. I was going to have more accidents the other day. After a while, it returns to normal, but I did not understand when and why. The other day, when my foot was in the clutch, when I applied the brake, it hardened and did not hold.
What could be the reason?
08.05.2020 15:30 # 2
There may be a problem in the vestinghouse or the main center.
08.05.2020 15:30 # 3
I think it might be in the main center.
08.05.2020 15:30 # 4
freestar206
Thank you guys for your answers, but I do not have much mechanical knowledge .. :) what is this main center and vesting house you said? Can you open up a little?
08.05.2020 15:30 # 5
[QUOTE = freestar206] Guys, thank you for your answers, but I do not have much mechanical knowledge .. :) what is this main center and vesting house? Can you open up a little? [/ QUOTE]
If you know the location of the brake fluid container when the bonnet is open (on the left fender side and there is a hydraulic filler cap at the top), the main brake center is the part that comes out from the brake pipes just below that container. There is another round piece in which the main center is connected just behind it. it is the westhouse. besides it is air supplement. This air assist ensures that the brake pedal is first soft. When the engine stops, after pressing the brake pedal 3-5 times, you can get a stone like you cannot. Because it leaves air inside the westhouse and becomes inoperable. in this case, you cannot stop the car. When the engine starts, it gets air again and becomes operational.
free to try.
stop the engine. With the pump 5-6 times, you will see that it is like stone afterwards. Meanwhile, hold down the brake pedal and start the engine of marsa foot down to the foot. Because when the engine starts, the westhouse will be activated ...
the cecol 2011-05-30 14:10:53
08.05.2020 15:30 # 6
freestar206
Thanks for the comments Cecoli. You explained very well ..
08.05.2020 15:30 # 7
[QUOTE = freestar206] Thanks for the comments Cecoli. You explained it very well .. [/ QUOTE]
I am not saying in vain to meet Sırıtma open the square open encyclopedia Kahkaha
you by_ 2011-05-30 14:45:10
08.05.2020 15:30 # 8
dbmaster
It may not be a problem. There is a hole in your westinhouse pipe. If it does not swell up, check the pipe, it came to me in the night. I closed the hole with a perforated electrical tape.
08.05.2020 15:30 # 9
[QUOTE = by_ersin] [QUOTE = freestar206] Thanks for the comments Cecoli. You explained it very well .. [/ QUOTE]
You are so much law Sırıtma
08.05.2020 15:30 # 10
Let's all live a lot ...
08.05.2020 15:30 # 11
tigerland
Look at the brake master, show it to the complete master. The most important thing is braking in the vehicle. It saves lives for 1 sec. I think you should go to the service immediately.
08.05.2020 15:30 # 12
asil16
my friends came to me today, the car was working in the idle, there was a name on the bank, whatever the name was, the car was on the light ramp, the car brake was lowered, I pressed the brake, the brake pedal did not come down, did not hold down, after the brakes, I shifted and put it on the brake, it was holding the brakes when I started again, what could be the reason for this, what was the reason for this? did not come to me
08.05.2020 15:30 # 13
I use 206 feline too, the brake swells when heavy people sit in the back :(
08.05.2020 15:30 # 14
mustafa486
exactly as it happens to me. If I haven't applied the brakes for a long time in traffic, suddenly it swells and keeps ABS weak. I shouldn't pay the brakers money, I want to go to the mechanic to find the problem and do it directly. please help
08.05.2020 15:30 # 15
[QUOTE = Erbin] Look at the brake master and show it to the complete master. The most important thing is braking in the vehicle. It saves lives for 1 sec. I think you should go to the service immediately. [/ QUOTE]
+1
08.05.2020 15:30 # 16
ose
Even if your vehicle is zero, try this and leave it on the brake 4-5 times in a row while it is idle. Anyway, that's another thing I said. Look at the brake master, show it to the complete master. The most important thing is braking in the vehicle. It saves lives for 1 sec. I think you should go to the service immediately.
