brake fluid reduction
08.05.2020 19:46 # 1
x571
Hi
when I look at the brake oil it shows the minimum level, can I take the oil and add it? is there any such thing that has been mentioned in some subjects about the braking of air? I will not drain the oil, I will just open the lid of the hopper and supplement it.
When the brake is pressed, there is a voice called back, as if you are scratching the writing board with a nail, as if you were applying a fork to the plate. what is this ?
How do I know if my brakes are leaking oil or have holes in them? Is fat reduction normal? I do not know if the previous owner of the vehicle has ever changed.
When I run the rear squeegee squirt, the sound of the motor is coming because there is no water. I tampered the hole with a needle, it did not improve, what should I do?
Where can I order the original spare parts of the vehicle from the internet except the service? Do we have such a facility or do we need service?
What belts are the belts marked in red in the picture. In the service book, the belts have changed in the 60,000s, should the vehicle be changed again at 98 thousand? How do I know when it's time to change?
08.05.2020 19:46 # 2
ALLEX
The high pitched sound that comes on when the brake is pressed is usually caused by the pads knocking on the disc when finished. You can add the brake hydraulic directly.
08.05.2020 19:46 # 3
x571
if you can help for other questions
08.05.2020 19:46 # 4
1-You can put the brake oil directly. As our allex brother says, have the linings checked.
2- There is a leak in places where brake oil does not fall to a stop. ok check it. If it continues, the brake center (westinghouse) must be checked, it may be faulty or there may be leakage from the hoses.
3-If the rear wiper water hose is free from the sprinkler and if it does not come from the hose, if it does not come from the hose, check the wiper water tank by disassembling and blowing the hose, or the hose may be clogged or disassemble the sprinkler you are trying to open with a needle, make it clean by blowing it, check it. (if there is water coming back)
4-You can get spare original spare parts of the vehicle online and from spare parts in the industry. our sponsor www.peugeotturkiye.co I Do öğrenebirlis arayarak ederesind career in Information, my phone deals.
5-yes, it seems like the benefit is quite worn when you change the belts. every 60000 km or max. Replace belts every 5 years. it is even better to change earlier in big traffic cities such as Istanbul.
