brake does not lock
08.05.2020 16:04 # 1
muntehaozen
Hello friends, I congratulate everyone.
My car is 2004 307 xt lpg.
I replaced my front discs and pads with the original one week ago.
The reason for replacing was that when I hung a little bit after pressing the brake, I could not use the performance of the brake, so I sounded like I was gnawing the wheels, and I did not use the performance of the brake. For this reason, I changed both the pads and the discs and I used it for a week, so I said I would hang on the brakes again yesterday so that I could use it for 1 week. I can't lock the wheels, I feel like iron is slipping on the iron, I feel it on the brake, I hear it as a sound.
I want you to comment from your experiences, what is not? What if I am in an emergency braking situation, I think I will not be able to stop the car: S
08.05.2020 16:04 # 2
deamod
Thanks. I congratulate everyone's feast.
I think you're talking about ABS. As far as I know ABS does not lock the wheels when it is engaged and prevents slipping, I think it is normal in the knock coming from your brake.
I know the truth is wrong, I do not know, masters will help more ...
08.05.2020 16:04 # 3
What you know is correct sec. deamod.
Since our vehicles have ABS braking system and the purpose in the ABS braking system is to prevent the wheels from locking, your brakes will not lock as much as you want. The part that you call that iron is blowing into iron is also caused by ABS.
For more detailed information: http://tr.wikipedia.org/wiki/ABS_fren_sistemi
08.05.2020 16:04 # 4
deamod
[QUOTE = koliva] What you know is correct sn. deamod.
Thank you koliva
08.05.2020 16:04 # 5
Friends did not give the necessary answer ...
Abs is a very useful system. It is necessary to have knowledge about the vehicle's technical equipment and features. Sırıtma
08.05.2020 16:04 # 6
muntehaozen
I hope it is normal as you say. When the brake is applied, it sounds like a piece of iron iron.
08.05.2020 16:04 # 7
Platinium
If the brakes of the car really have a problem, let's get it done, but yours is like a normal situation, don't obsess too much. Sırıtma
08.05.2020 16:04 # 8
metin
normal of course. It is also called anti-blocking system which is used to prevent blocking / locking.
The vehicle will come out of the control because it slips when the tire is locked during braking. abs reads the rotation of the tire and when the tire is locked, it brakes the tire and brakes again. In this way, you can stop the vehicle at the shortest distance and without leaving the road. If the tires are worn or the floor you brake is slippery, dusty, wet, that is, if there is a ground that requires the tire to slide quickly, then the abs will be activated. As a symptom, the friction sound of iron in the brakes and trembling in the pedal.
If you told the master who changed the disc and pad what they said and if the abs was not mind and the disc changed the pad, I would recommend you not to go to that master again.
