Brake Discs Get Hot
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » Partner tepee
14.10.2020 20:36 # 1
selcukcolak6161
Hello friends. The brake discs of the 2012 partner vehicle are extremely hot in my opinion. We showed it to 2 masters and it was said that it is normal, but sometimes the discs are too hot to hold. Do you think there is a problem or is it normal
14.10.2020 21:27 # 2
Murat062
Hello, my old vehicle was in the fiese. It would be like that too. Sometimes it would get too hot to touch the wheels. I took it to a few masters, they said normal. I got on for 6 years, I didn't see any damage. Those with the same brand tool will help better in this regard.
15.10.2020 11:09 # 3
It's normal to get warm, sir. There is no problem in a city with abundant slopes like the Black Sea. If you want a little more performance, there are carbon discs and pads, the prices are high. also load with your vehicle etc. it will get hotter if you are carrying it.
15.10.2020 12:14 # 4
selcukcolak6161
However, I use it for 5 minutes, I almost do not brake, but it still gets hot. I use my company vehicle, the doblo, for 5-6 hours a day, there is almost no heating. My Peugeot tires will burn almost 😂
15.10.2020 13:07 # 5
Have you checked the front wheel hubs and bearings, sir? If the bearing is defective, it may cause overheating. Frankly, I do not want to comment much without seeing
15.10.2020 14:36 # 6
oguzhan53
There was overheating in the dam, there were bolts moving in the calipers in a lining change, it was determined that they did not move well, we changed it, after that day there is only a normal warming
16.10.2020 09:21 # 7
In addition, I say change the brake hydraulic oil once.
16.10.2020 16:13 # 8
selcukcolak6161
All of the masters I showed in the industry said normal. Front pads changed 1 week ago, I think the brake fluid has also changed. I think it's best to consult Peugeot Authorized Service.
20.10.2020 23:38 # 9
x571
[QUOTE = selcukcolak6161] All the masters I showed in the industry said normal. Front pads changed 1 week ago, I think the brake fluid has also changed. I think it's best to consult Peugeot Authorized Service [/ QUOTE]. It's not normal. it does not warm up out of nowhere. Especially with 3-5 brakes it never gets hot. There is a certain problem in the caliper crew, it is tightening the disc. That's why a service van burned down 3 years ago.
22.10.2020 10:16 # 10
pusutr
I think the pad gets hot when it is constantly rubbing against the disc. I think it is useful to concentrate on this. It is not normal to warm up after 5 to 10 minutes, it is abnormal. I recommend you to have it done as soon as possible. I hope it doesn't cause any of you.
23.10.2020 17:29 # 11
GokhaN
merhabadisk, this gets hot, it should not be done without manual heat control. If your brake is holding, it's okay
