Brake and Steering Hydraulic oil change time
08.05.2020 15:57 # 1
vbmaster
Friends, how soon should these two oils be changed? or should I never handle?
Will there be softening when the steering hydraulic oil changes?
08.05.2020 15:57 # 2
vbmaster
Also, do these hydraulic oils have a filter? should they change if any?
08.05.2020 15:57 # 3
I do not know if my friend has a certain time, but it seems to me that it makes the most sense to check and change. if it fell below the level, there may be a change
08.05.2020 15:57 # 4
vbmaster
ok ... handicraft saying then ...
08.05.2020 15:57 # 5
Check if the level is low. If the steering wheel is too hard, change the oil completely.
08.05.2020 15:57 # 6
badcombatant
I don't know the hydraulics, I've never changed Embarrassed
But when we saw the discs, we noticed that there was scratches and cracks on the discs in the control.
It is necessary to pay attention to the discs, washing the discs when they are hot, hitting the water, entering the water, when the cold encounters extreme heat, deformations on the discs may even cause the bending and twisting of the disc. Even the new zero disc may become unusable in a very short time.
08.05.2020 15:57 # 7
badcombatant
I read the hoops brake and steering wheel as a brake disc sorry sorry Confused
08.05.2020 15:57 # 8
vbmaster
No problem information is knowledge :)
08.05.2020 15:57 # 9
statistican
only the oil level should be checked, if it is missing, it should be added, if it does not subside easily, there is a leak or something.
08.05.2020 15:57 # 10
vbmaster
But as if the oil had been a strange black trouble, the estimate was 100 thousand.
08.05.2020 15:57 # 11
statistican
I must be yellow, change it :))
08.05.2020 15:57 # 12
vbmaster
Is it yellow, brother as black as obama :)
08.05.2020 15:57 # 13
metin
[QUOTE = statistican] only check the oil level, add it if it is missing, even if it does not diminish easily, there is a leak or something to check [/ QUOTE]
Yes, the oil level should be checked, if it is missing, it should be added, but it should be changed when it reaches a certain km.
No oil is lifetime, even when the level is full, steering and brake oil should be changed like other engine oil etc. consequently, they are the servant structure and the times lose their characteristics.
text 2011-08-08 08:51:43
08.05.2020 15:57 # 14
statistican
black as obama ha :) change the brother, check from time to time very important hydraulics
08.05.2020 15:57 # 15
vbmaster
This is interesting. can i change it in front of the house?
