BRAIN RESET (BSI) |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 308 (2008-2013) | |
| 08.05.2020 20:50 | # 1 |
| 08.05.2020 20:50 | # 2 |
The first option came to me differently. Why should the glass come down?
| 08.05.2020 20:50 | # 3 |
As if it was written to make fun of. What are you reaching out from the window? If it is a method that is really applied, when someone was in the vehicle, someone else said to remove the battery terminals. If it will not be reset when it is not hanging from the glass, it will
| 08.05.2020 20:50 | # 4 |
Let me write the incident that happened to me. While they are on the road, they pour bitumen into the soil and pour pebbles on them in rural areas (they call it asphalt). They said say do it on another pug site. Apply margarine to the parts of the car in the evening, wash the car after a day. All of them are gone. He washed the car, took a gauze in his hand, wiped them all in 2 minutes. I think it's a beautifully edited article.
| 08.05.2020 20:50 | # 5 |
maximusti |
How do you think to turn the ignition after removing and installing the pole cap without opening the door? this is a different bsi reset method: You can use the BSi restart procedure below to detect changes on the vehicle and for possible BSi brain problems. This application is a recommended application. I am absolutely not responsible for the opposite situations that may occur during this application. Good luck with. - If the vehicle is running, STOP the engine and turn off the parts that will draw electricity such as headlights, signals, radios, air conditioners on the vehicle. Open the window of the driver's side, unlock the bonnet lock. - Remove the key from the ignition and get out of the vehicle and close the doors. Wait at least 3 minutes after closing the doors. - Open engine hood and remove Battery (+) terminal. Wait for --30s and reattach the pole. Wait another --30s and turn the headlamp lever to the parking position without opening the door. Open the door, insert the key into the ignition and put it in battery mode. --While the key is in battery mode, press and hold the lock button of the key for 10 seconds. --Remove the key and lock the vehicle, turn it back on then run it and check if the problem persists. That's it. If your problem is not solved, you can repeat this process a few more times. If there is no solution, please contact the nearest service. excerpt from a different site.
| 08.05.2020 20:50 | # 6 |
Yes, things like this are going around, would it be a problem if I tried? Let's not break the brain after all
| 08.05.2020 20:50 | # 7 |
Don't be fooled, don't believe these poles.
| 08.05.2020 20:50 | # 8 |
I think it's best to take it to the service
| 08.05.2020 20:50 | # 9 |
maximusti |
[QUOTE = Gboz3510] I guess it's best to take it to the service [/ QUOTE] what exactly is the problem with the vehicle?
| 08.05.2020 20:50 | # 10 |
[QUOTE = maximusti] [QUOTE = Gboz3510] I think it is best to take it to the service [/ QUOTE] what exactly is the problem with the vehicle? [/ QUOTE] The problem is the vehicle is missing in rolent. The first cylinder head gasket was burned and then tested, it turned out to be solid, and now these tools are not fully compatible with the tube, they were kicking. By the way, the lpg system in the vehicle is poor.
| 08.05.2020 20:50 | # 11 |
maximusti |
[QUOTE = Gboz3510] [QUOTE = maximusti] [QUOTE = Gboz3510] I think it is best to take it to the service [/ QUOTE] what exactly is the problem with the vehicle? [/ QUOTE] The problem is the vehicle is missing in rolent. The first cylinder head gasket was burned and then tested, it turned out to be solid, and now these tools are not fully compatible with the tube, they were kicking. By the way, the lpg system in the vehicle is poor. [/ QUOTE] bsi reset is not something to be fixed, I don't know exactly what the bsi reset event is but what exactly. you really need to find and show a master who understands from peugeot. According to my estimates of fluctuation in idling: Spark plug spark plug cable gas butterfly lpg setting / brain may be doing these.
| 08.05.2020 20:50 | # 12 |
You have to do it while the margarine is melting in hot weather. Apply thinner to the cloth and wipe it.
