BRAIN LOCKING
08.05.2020 16:36 # 1
sefa
FRIENDS PEUGET 307 BRAND 2006 MODEL VEHICLE LOCKED THE ENGINE. SERVICE TELLED THAT THE KI & nbsp; PROBLEM IS ELECTRONIC WILL RETURN TO FACTORY SETTINGS. DOES THE VEHICLE REPEAT THE FAULT IN THIS LOCATION OR GIVE THIS FAULT TO OTHER FAILURES? (EXAMPLE: GLASS SENSORS OR ANYTHING)
08.05.2020 16:36 # 2
okankrgz
Take a look at the impact sensor. First of all, the kits will start in any impact.
08.05.2020 16:36 # 3
okankrgz
if the brain is to be reset, the malfunction will not recur
08.05.2020 16:36 # 4
sefa
YES THE BRAIN RESET WILL BE DISCONNECTED. & Nbsp; WHAT I FEAR & Nbsp; THE REPEATMENT OF THE FAILURE OR THE FAILURE TO FAILURE TO THE SENSORS OR OTHER ELECTRONIC PARTS.
08.05.2020 16:36 # 5
estair
How to reset the brain to & nbsp; Is there anyone who can give an idea?
08.05.2020 16:36 # 6
[QUOTE = estair] how to reset the brain & nbsp; Do you have any idea to go to the service? The above mentioned process is the process of returning back to the factory settings made with the PP2000 in the BSI or ECU, so that the changes made later can be returned to their initial settings and are different from each other. There is no need to go to the service for this process if you have PP2000 "Embarrassed"
koliva 2012-02-27 22:45:15
08.05.2020 16:36 # 7
scorpions_64
[QUOTE = sefa] FRIENDS PEUGET 307 BRAND 2006 MODEL VEHICLE KITTED THE ENGINE. SERVICE TELLED THAT THE KI & nbsp; PROBLEM IS ELECTRONIC WILL RETURN TO FACTORY SETTINGS. DOES THE VEHICLE REPEAT THE FAULT IN THIS LOCATION OR GIVE THIS FAULT TO OTHER FAILURES? (EXAMPLE: WINDOWS SENSORS OR ANYTHING) [/ QUOTE]
ahh ahh what we pulled from these body shops. In short, let's say we pull from industry. brother, first of all I just read the problem. I recently left the vehicle to the body shop to replace the front tank of the vehicle. Everything was fine, I removed the vehicle, the next day, when I wanted to start the vehicle, I said that the temperature of the temperature rose instantly and lowered. As a result of my research for 2 months, I got out of the brain and sent it for repair. I guess it will come tomorrow today, now it is good ...
08.05.2020 16:36 # 8
okankrgz
In peugeot, a lot of things were psychological, so I removed my car on the fiber when I lowered it, the abs was disabled, 1-2 contacts closed and opened everything was milk port :)
08.05.2020 16:36 # 9
scorpions_64
[QUOTE = okankrgz] in peugeot, a lot of things were so psychological :) I lifted my car on the fiber when I lowered it, the abs was disabled when 1-2 contacts closed and opened everything was milk port :)) the fault is enough to cool off the vehicle anyway ...
08.05.2020 16:36 # 10
cinecommentator
not psychological..CHRONIC ... the car's diseased DNA seems to be corrupt.
If BSI is failing, the basis of this failure is not hopefully.
08.05.2020 16:36 # 11
djchaos
There may be a problem due to the impact, the brain protects itself and the motor and locks it (as far as I know).
08.05.2020 16:36 # 12
zerzevat
my friends also stood for a year, stopping timelessly.
1 month ago I pulled into the parking lot. I returned 1 hour later and it did not work again. I wrote the details on other topics.
my brain is also locked. but the service failed to reset. Does anyone know the detail of the job? does not ignite. starter gasoline, pump, crank sensor are all ok. There is no ignition.
it is said that the brain will change.
08.05.2020 16:36 # 13
scorpions_64
[QUOTE = zerzevat] friends too, my vehicle was stopping for a year, stopping timelessly.
my brain is also locked. but the service failed to reset. Does anyone know the detail of the job? does not ignite. starter gasoline, pump, crank sensor are all ok. no ignition.
first get past ... the service does not deal with the brain reset, it just changes it. At the time, I was dealing with the same fault in my vehicle. as a result, I had the brain repaired. What is your vehicle model? 206 gti, I have one brain that I got as a result of misdiagnosis, let's talk privately. & Nbsp;
08.05.2020 16:36 # 14
zerzevat
thank you. I have a complete set change in my head. With exiting ....
vehicle 1.4 bva 2004 model. sagem s2000 brain.
08.05.2020 16:36 # 15
scorpions_64
[QUOTE = vegetables] thank you. I have a complete set change in my head. With exiting ....
you are welcome, no gti brain in my hand, brand will not be marelli to your vehicle. & nbsp;
